Old 01-30-2012, 09:48 PM   #1
JRANGER
JRANGER's Avatar
Help me get new tires!
Well my tires are worn out and since im getting my Tax Return I figure I might as well get rubber for the truck in case the roads get icy...That is what i bought her for in the first place anyway...
So that being said....
I have 255/70R15's on the truck....Can I go bigger without messing up the speedo? I have a 21 gear speedometer gear and ell all I know about the rear end is a couple #s on the axel.... which are 1249578 R which was on the bottom.. On the 0 FI680...all though the 0 look like a flat head almost haha
Im wanting a good tire for winter as this truck isnt going to be driven on the regular
JRANGER is offline   Reply With Quote
Old 01-30-2012, 10:31 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Help me get new tires!
You can only go wider. Taller will change the speedo. You can change the tire ratio by going different size rim.
Check out this nifty calculator.
http://www.miata.net/garage/tirecalc.html
You can change the driven gear to compensate.
Find the correct drive and driven gears with this calculator.
http://www.tciauto.com/tc/speedo-info
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-30-2012, 10:43 PM   #3
JRANGER
JRANGER's Avatar
Do you know the stock rear gear size? Stock tire size? Wondering if the guy I bought it changed out the tires and rims for not standard size...Gear is rusty and looks stock
Old 01-30-2012, 10:56 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
A 78 C10 came with 225/75-15's, I would assume GMC's did as well. Look on the inside of your glovebox door, Likely would be on the option/build list.
There's no telling what's been changed if anything.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-30-2012, 11:06 PM   #5
JRANGER
JRANGER's Avatar
Shows me nothing...closet thing on my build list L78-15/B TBLS HWY BL and i have no clue what that is lol
Old 01-30-2012, 11:10 PM   #6
Restrorob
Restrorob's Avatar
L78-15 converts over to a 235/75R15 size, they're 28.88 dia. and your 255's are 29.06.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 01-30-2012, 11:12 PM   #7
JRANGER
JRANGER's Avatar
ahhh so my tires are wrong.....and my speedo is prob wrong which would explain why my mom said i was going 80 hen i drove the truck home when i thought i was going 70/75
Old 01-30-2012, 11:16 PM   #8
billybobjimmyjoejack
I ordered my 1978 C10 in October of 1977 and took possession of it on Jan. 10th of 1978. I still have the truck and it has one of the original tires as a spare L78-15 is the size that came with the truck. The gear ratio was 3:07 and it is a BIG 10.
billybobjimmyjoejack is offline   Reply With Quote
Old 01-30-2012, 11:18 PM   #9
Restrorob
Restrorob's Avatar
Yep..... The tires on the back of my 97 are smaller than stock and I don't know what else was changed, so my speedo is about 12 miles off.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 01-30-2012, 11:21 PM   #10
JRANGER
JRANGER's Avatar
hmm weird..Based on the information with the calcs my base gear should be a driven gear of 44 but i think i remember it being green which is 42...... Based on that and the 29" diameter I should be using a 20 tooth gear?? Sound right to yall?
Or based on the tire calc i could put on 265/75 15s
Old 01-30-2012, 11:31 PM   #11
Restrorob
Restrorob's Avatar
Sorry, Never used that calc. before.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
