Truck Junkie
![]() Join Date: Aug 2008
454 Mystery
Ok I'm building a 30 over 99 454 using a zz502 roller cam lifters and 3/8s pushrods. New melling hi volume oil pump rings bearings etc. Now here's the problem I've primed the engine and I'm getting oil to the rockers on the drivers side but nothing, zip,nada to the rockers on the passenger side I turned the motor a number of times. I'm getting good flow to the drivers side but nothing to the passenger. I'm using an electric drill 800 rpms max. I have 40 lbs of oil pressure. I'm really stumped! Any help will be greatly appreciated .
Posted via Mobile Device Posted via Mobile Device |
BAD BOW-Silverado XST
Re: 454 Mystery
What type of priming tool are you using?
![]() You need one like this one. The bottom part seals the proper oiling passages to send oil to the entire block. |
Truck Junkie
Re: 454 Mystery
One just like your picture. Greg
Just here to tinker
![]() Join Date: Jun 2008
Re: 454 Mystery
There must be an alignment issue with your priming tool. That groove in the lower aluminum piece is there so that oil can flow around it. I'm guessing that that groove is not aligned properly in the block.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Re: 454 Mystery
Can you install the distributor hold down bracket? Is the top flat plate flush with the intake? Was the engine rebuilt?
Truck Junkie
Re: 454 Mystery
Yeah I'm building the engine I haven't put the intake on yet though.
Re: 454 Mystery
Are all the oil galley plugs in place?
Make sure the ones in the lifter valley are there...had a buddy who built one and left those out. Oil everywhere except where he needed it. |
Truck Junkie
Re: 454 Mystery
Yep all the plugs are in the galleys
Re: 454 Mystery
Did you check to make sure all oil gallies weren't plugged, like the crank, heads, etc?
1976 GMC SIERRA CLASSIC CAMPER SPECIAL! 454 BIG BLOCK ![]() |
Re: 454 Mystery
Spin the crank
Truck Junkie
Re: 454 Mystery
I've spun many times no change
Re: 454 Mystery
Pull the plugs so there is no compression and add the distributor. And hook it up to a battery charger and crank it till some oil comes out the other side.
But honestly once the engine fires within 10 secs the lifters and rockers on both side will have planty of oil. This is why I usually use bearing grease on all surfaces just in case You should be fine though. Just make sure your using zinc additive or break in oil too Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#13 |
Truck Junkie
Re: 454 Mystery
Thanks for the info!
#14 |
Truck Junkie
Re: 454 Mystery
Solved the mystery. The intake port on the roller lifter has to face the oil galley in the block. I moved them and they are all oiling. Thanks for everyone help Greg
#15 |
Re: 454 Mystery
Good news! always great to solve a mystery
#16 |
![]() Join Date: Mar 2010
Re: 454 Mystery
Very helpful info. Any chance you could post a pic of the lifters the right way and wrong way?
#17 |
Re: 454 Mystery
Wow, I'd never have thought it would matter in a pressurized galley.
Learn something every day, thanks for that!!! |
#18 |
Truck Junkie
Re: 454 Mystery
Sorry I already put them back in. Just hold the lifter and turn it till u find the small hole in the side when you put it in the lifter bore make sure the little hole is facing to the rear of the block. You can see the oil galley in the lifter bore before you drop in the lifter. This only applies to roller lifters because the don't turn in the bore as flat tappet lifters do. My bbc is a 99 roller motor the oil flow in the oil galley is rear to front. Thanks again for all the input. Greg
#19 | |
Re: 454 Mystery
#20 |
Re: 454 Mystery
This still doesn't make sense to me.
Flat tappet lifters rotate, but not very fast. This would mean that they weren't properly oiled except when the hole is facing the direction of oil flow. I've built several 350's and a few 454's with OEM roller lifters. I never paid any attention to the direction the oil hole was facing, but there's not a chance that they're all in facing the right direction. Not with a 50/50 chance. I think something else you did either fixed it or there was a big air bubble or something blocking flow to that side. No matter, it's fixed now and that's the main thing. |
#21 |
Re: 454 Mystery
Ya I kinda had a question there too, just didn't have time to post it. If you're running roller lifters, they have the linkage between them right? Why on one side would you have the linkage towards the valley and on the other side have it towards the cylinders? I'm kinda confused on what your saying here, that's why i asked for pics. I'm not building a roller assembly right now but I'm just not sure where the confusion is at...With a non roller lifter motor they do spin and get oil accordingly. On the roller lifters they are stuck in one position. Sounds to me like you don't actually have roller lifters. Of course, I have never built a motor this new soooo, I just don't know...
#22 |
Truck Junkie
Re: 454 Mystery
I have roller lifters all right. They are gm lifters that have a retainer to keep them from rotating. I know the aftermarket rollers have a bar. Gm doesn't use that style.
