Old 01-31-2012, 11:17 AM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
trucks gone crazy
this moring went to clear snow off my truck and warm it up. went to use the wipers to clear remainder of snow off window and they didnt move (thought the were frozen) so i made sure they wernt then tryed again same thing but i noticed the guages go all crazy :S
any ideas?
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 01-31-2012, 11:23 AM   #2
Tucson38
Re: trucks gone crazy
Any chance the ignition switch was stuck in the "start" position?
Tucson38 is offline   Reply With Quote
Old 01-31-2012, 11:35 AM   #3
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
nope it cycles through like normal.
Old 01-31-2012, 01:04 PM   #4
stroker87
bad ground?
stroker87 is offline   Reply With Quote
Old 01-31-2012, 03:31 PM   #5
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Originally Posted by stroker87 View Post
bad ground?
works now? :S WTH lol
Old 01-31-2012, 05:55 PM   #6
donut
donut's Avatar
bad ground?
I had an '89 that did similar. Going down the road (2:00am) and gauges freaked and the lights shut off. I'm still driving! (55mph, no less)
Turned out to be the engine to firewall ground broke. Most of the time it made decent contact, but flex the truck just right...
Just happened to find it tracing some wire looking for burn't/cut spots and hit it with my hand.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-01-2012, 05:17 PM   #7
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
will take a peek thanks.
Old 02-01-2012, 08:12 PM   #8
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I know it's work'n now. but you cycles like normal ? you mean the key cycle's, the actual ignition switch is at the bottom of the collum, it could stick and the seem normal.
worth check'n to see if the rod is bind'n some where.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-01-2012, 08:42 PM   #9
71swb4x4
71swb4x4's Avatar
I also think it may be a ground. Check them all over well, if in doubt add extras.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-01-2012, 10:05 PM   #10
1LowToy
Sounds like your wipers have taken a hint from your avtar
1LowToy is offline   Reply With Quote
