01-31-2012, 12:21 PM | #1 |
It followed me home?
spring hangers
Will 4wd rear leaf (rear leaf front hanger) spring hangers work on a 2wd? If so will it result in a lift or drop on stock suspendion?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-31-2012, 02:14 PM | #2 |
Re: spring hangers
Yes they will work and will give you about a two inch lift.
74 swb 71 2wd Jimmy 82 2wd Blazer |
01-31-2012, 11:57 PM | #3 |
Truck Nut
Re: spring hangers
I had the same idea the other day cochino. Also Bell tech makes a short rear shackle that is suppose to raise it up some.
Tony Kee Texas Square Bodies |
02-01-2012, 12:21 AM | #4 |
Re: spring hangers
I gave the wrong answer. I don't know about the front hanger. Look at the LMC catalog and you should be able to see if they are different.
