Old 01-31-2012, 01:21 PM   #1
67Slider
67Slider's Avatar
Aftermarket Door Handles - Any Good?
Has anyone had any luck with aftermarket exterior door handles? I am looking at Classic Parts, Classic Ind, Truckandcarshop and some others but don't see any real differnece in quality or manufacturer. NOS is hard to find and big $$$. Any suggestions or comments?
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 01-31-2012, 03:47 PM   #2
Fldawg
Fldawg's Avatar
Re: Aftermarket Door Handles - Any Good?
got a set from brothers and so far so good and it's been 2 years
Fldawg is offline   Reply With Quote
Old 01-31-2012, 04:12 PM   #3
DT1
DT1's Avatar
Got mine from LMC. One of the few parts from them that has actually held up good.
DT1 is offline   Reply With Quote
Old 01-31-2012, 04:28 PM   #4
tr69c10
I got mine from the truck shop they lasted about two years
tr69c10 is offline   Reply With Quote
Old 01-31-2012, 04:47 PM   #5
Tim Christian
Tim Christian's Avatar
If you have true 67 doors none of them will fit without mods
Tim Christian is offline   Reply With Quote
Old 01-31-2012, 05:09 PM   #6
67Slider
67Slider's Avatar
I know one is not but I can't remember if I changed them both out or if I kept one of the original. I'm pretty sure I replaced them both because the originals were cut in the door for speakers. I do recall seeing the teardrop holes in the back when I was painting tho. My luck is I have one of each.
What kind of modification is neccesary?
I heard the OER stuff from Classic Ind is pretty good.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-31-2012, 05:14 PM   #7
webfoot
I would be surprised if there was any more than 1 manufacturer, so it doesn't matter really where you buy them from.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 01-31-2012, 05:15 PM   #8
bundeber
I haven't used the truck ones, but the OER handles I got for my 68 camaro from them were excellent. Heavy duty, good seals, good construction. I did have to adjust the plunger rod for my car, it comes long and needs to be test fit several times. I imagine the truck ones are similar and will need to be trimmed too. I'd buy a set from them in a heartbeat. If they are as nice as the camaro ones, they'll be good to go.
bundeber is offline   Reply With Quote
Old 01-31-2012, 07:57 PM   #9
Tim Christian
They are two different styles on the market one style is like orginals and one had rivited plates
Old 01-31-2012, 09:55 PM   #10
rkn463
rkn463's Avatar
I knew the interior was different but what is different about the exterior? I just ordered some from the Truck Shop and they listed the exterior as 67-72 (as does LMC) LMC does list a different part # for the interior part. Can you shed some light on this?
Thanks in advance,
Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
Old 01-31-2012, 10:32 PM   #11
DT1
DT1's Avatar
Two years! Are you kidding me? I put one on my passenger door over five years ago and it still works perfectly. Maybe it's because no one ever opens that door.
Old 01-31-2012, 11:32 PM   #12
67Slider
67Slider's Avatar
I just ordered some from GMCPaul. They won't go on the truck for awhile but I've heard nothing but good things about the stuff he sells. I will post when I get them.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 01-31-2012, 11:53 PM   #13
cflvulcan
cflvulcan's Avatar
I bought a set from lmc and not two weeks being on my 69, the passenger side push button went all the way in due to the spring blew out the backside cause the cheap tabs broke. Had to modify to make work again. But other than that they fit great and so far the finish has held up for the past year.
cflvulcan is offline   Reply With Quote
Old 02-01-2012, 02:50 AM   #14
sanford66
sanford66's Avatar
More info on this ^ please. I'm going to say that the original handles sucked from day one at the factory. They were poorly designed with pot-metal tabs holding the button/spring plate in place and prone to breaking. I know because i've had two other trucks that the handles broke on me. I'm crossing my fingers that they don't break on the truck i have now. I would like to see a pic of the rivited plate handles, seems like they would be an improvement over the stock handles. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 02-01-2012, 07:22 AM   #15
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Thumbs down Re: Aftermarket Door Handles - Any Good?
Never a problem with them working but unless your truck leads a sheltered life inside a garage most of the time, expect them to start pitting anywhere from 6 months to a year! As time goes by, they'll keep getting worse and soon look just as bad as the ones you replaced.
This is another one of those "buy over and over and over parts".
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 02-01-2012, 09:24 AM   #16
Tim Christian
Hey bobs409 just wondering have you ever bought anything you liked????? LOL!!!
Old 02-01-2012, 09:27 AM   #17
1972RedNeck
1972RedNeck's Avatar
I got some from brothers and they might have lasted 25 times.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-02-2012, 07:29 AM   #18
bobs409
bobs409's Avatar
Just tellin' it like it is Tim.
Some repro parts are garbage, you should know that.
$85 dollar floor mats that dryrot within 2 years, door handles that pit in 6 months, etc. I'll tell (warn) anyone and everyone I can about the bad ones.
The parts I've never mentioned are the good ones.
Bob
Old 02-02-2012, 07:51 AM   #19
Yeah,OEM was junk from the get go. It only lasted over 30 years then a small portion have failed. They really should last forever.
Sorry,just had to comment ere. I see people call OEM stuff poor quality as if they forgot how long it lasted. Figure most people never even lubed these "moving" parts when they get used more times than the truck was ever run. It'll take a few decades before we know if any repros are an improvement over OEM. The only failure I've ever seen is a broken spring on a couple trucks,which is metal fatigue.
