Old 01-31-2012, 09:35 PM   #1
burbluv
burbluv's Avatar
1962 Deluxe Instrument Cluster Build
OK I need confirmation that I can combine the following items to make my dream instrument cluster. It is going to take some cash to put it together but before I start the collection I want to make sure I am getting the right things so here they are.
I also added some literature that says for clocks all Chevy IIs number 985581.
So I am hoping when I get the tach and clock that they should slide in snugly and work with no problems except carefully drilling out a tiny hole for the clock bezel????
Thanks,
AJ
burbluv is offline   Reply With Quote
Old 01-31-2012, 10:01 PM   #2
MusicMan70
MusicMan70's Avatar
Re: 1962 Deluxe Instrument Cluster Build
Sorry I can't confirm any of this AJ, but I want to say, I like what you've chosen and see the vision you have for the Cluster. It should turn out very nice; subscribed for the final results.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 01-31-2012, 10:11 PM   #3
jocko
jocko's Avatar
Oh my Lord, I'd probably crack 5 instrument cluster lenses before I got the hole right.
Here's a question, since it sounds like you are wanting to know if the clock will slide in in the right empty panel as if it were stock. Don't quote me (in other words, somebody please correct me...) I THOUGHT that the only clock option in a 62 truck was for the one that was EXTERNAL to the instrument cluster - mounted to the dash and usually cost more than my truck...? Have never seen a factory in-dash clock on a 62. I realize the brochure shows a "clock" but the one for the truck looks like it's the face of the external one that was an option and that you have the Chevy II clock, perhaps.
Now, that does NOT mean it won't fit or won't work. And an in-dash one may have actually been available - that's what I'm hoping to learn from this post.
I think the clock you have will certainly look great, even if it does require mounting mods. If it doesn't require any, you'll have inadvertently started a mad rush of orders for that clock you bought...
Old 01-31-2012, 10:20 PM   #4
burbluv
burbluv's Avatar
I found a very similar 64-66 cluster that 198plus owned but I have not been able to figure out for the life of me what clock is in it. I think I read somewhere it came out of something late 60's and I am not sure if it is me or my eyes but I think it is white and not green. I could be mistaken. Any help would be great.
Old 02-01-2012, 12:08 AM   #5
burbluv
burbluv's Avatar
So does anyone know if I am going to need to dremel or cut out the lower half circle on the clock side or does it just pop out? It is hard for me to tell from photos and I do not have a 60-63 deluxe instrument cluster yet.
Old 02-01-2012, 09:53 AM   #6
1963c-10
1963c-10's Avatar
If you flip the guage cluster over, there are basically 3 main components. Looking at the back of the cluster...You have a pod that holds the tach, fuel and oil pressure guage.....the speedometer....and a pod that hold the ammeter, temp and either a delete plate, vacuum guage or air pressure guage.....or in your case a clock. The pods are screwed in to the back of the cluster. From the front looking at it as it were mounted in the truck....you have the metal bezel, a plastic lens that covers the cluster, a metal plate (which is what you will have to trim) and the cluster housing. They are fairly simple once you get into them. The factory clocks were externally mounted. Normally found on top of the dash in the center.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-01-2012, 10:51 AM   #7
1963c-10
1963c-10's Avatar
Heres a pic of aerotruk63's clock. This is the correct clock and mounting location in the center of the top of the dash
Old 02-01-2012, 10:52 AM   #8
1963c-10
1963c-10's Avatar
And another clock mounted in dash
Old 02-01-2012, 10:53 AM   #9
1963c-10
1963c-10's Avatar
And just for the GMC guys...this is the GM clock
Old 02-01-2012, 11:26 AM   #10
burbluv
burbluv's Avatar
I guess if I wanted to go more original I could look for a vacuum gauge and not have to worry about cutting anything. Does anyone know where I can find one of those?
Old 02-01-2012, 11:46 AM   #11
1963c-10
1963c-10's Avatar
PM sent on vac guage
Old 02-01-2012, 11:54 AM   #12
1963c-10
1963c-10's Avatar
Heres a pic of the vacuum guage. It bolts in to the left pod and all you have to do is hook up a vac line to it. Simple install. These are pretty hard to find. Have only seen a handfull of them. Sorry bout the bad pic...with the chrome bezel you get alot of reflection
Old 02-01-2012, 10:50 PM   #13
burbluv
burbluv's Avatar
Lost my vacuum gauge lead and looking for another one if anyone has one for sale.
Old 02-02-2012, 09:37 AM   #14
1963c-10
1963c-10's Avatar
I can check with 1 other person. If he doesn't have one....good luck.
Old 02-09-2013, 11:00 AM   #15
Dano0579
Dano0579's Avatar
I hope you don't mind me asking but what does all the pull knobs for on the dashboard?
Dano0579 is offline   Reply With Quote
Old 02-09-2013, 01:17 PM   #16
aerotruk63
aerotruk63's Avatar
Left to Right
Headlights-Wiper-Choke ---- Throttle Cable- Ignition Switch- Cigarette Lighter
Old 02-09-2013, 01:18 PM   #17
aerotruk63
aerotruk63's Avatar
Ops. The knobs under the dash is for the foot vents 60-61.
Old 02-09-2013, 01:25 PM   #18
Dano0579
Dano0579's Avatar
Thank you so much.
Old 02-09-2013, 01:57 PM   #19
aerotruk63
aerotruk63's Avatar
Better shot of an original clock. Seen these in Ford trucks with a different base.
Corvair with a different base.
Old 09-21-2014, 06:55 AM   #20
64chevycrewcab
1963c-10 is that GMC clock for sale?
1961 Apache 10 with side trim
1964 4 door crew cab C20
1966 Chevy Suburban with custom trim
1961 K30 with a 4-53T Detroit diesel
1966 GMC 4X4 Suburban
64chevycrewcab is offline   Reply With Quote
Old 06-10-2019, 08:29 PM   #21
Brad54
Brad54's Avatar
How'd this clock swap ever turn out?
Looking at it, I think it's a great idea!!!
I've wanted to do a clock in my instrument cluster, and I think this is the perfect fit.
Because nothing is EVER simple in my life, I'd put the tach over on the driver's side spot, and the clock on the passenger side hole where the tach usually is, so my passenger can also see the clock if she wants to glance at it.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
chevy ii, clock, deluxe cluster, tach
