Old 01-31-2012, 11:22 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Hood Fix
The hood on my 78 has started to get that typical bow. I am putting new hinges on it but I was wondering if anyone has tried to straighten one out by themselves. It seems to me even if you keep the hinges well lubed I will still need to put some kind if stiffener on it. Anybody added stiffeners to theirs. Pictures please.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 01-31-2012, 11:42 PM   #2
maskale
Re: Hood Fix
I have some, not yet installed, but this is for my 76 truck.
LMC had them
maskale is offline   Reply With Quote
Old 01-31-2012, 11:59 PM   #3
bowtiemanchevyman
bowtiemanchevyman's Avatar
Re: Hood Fix
yes i have and you do need it. new hinges will not fix the problem. even if u put a new hood on it will happen again.
and no pic of if you can make them your self to
bowtiemanchevyman is offline   Reply With Quote
Old 02-01-2012, 12:35 AM   #4
texastruckjunky
texastruckjunky's Avatar
Re: Hood Fix
After you put your new hood, always push in when pulling the hood down that will also help from it bending.
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 02-01-2012, 01:09 AM   #5
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
Re: Hood Fix
One of the first things I ever did when I bought my '78 new was to install the hood stiffners.
1978 Chevy SWB C-10 2WD 454/400
78 Big10 454 is offline   Reply With Quote
Old 02-01-2012, 01:33 AM   #6
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Hood Fix
I learned a trick to help keep this from happening with my old 74 c10.
Instead of pulling straight down on the front of the hood, first push the front of the hood BACK (not up) to pre stretch the springs and get the hinges out of their "locked position."
THEN you can pull down and close the hood with never any problems.
Although your own reach and height of your hood when open are also factors to take into consideration.
Learned this trick from my older brother years ago.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-01-2012, 08:31 AM   #7
xrcr
Re: Hood Fix
X2 or 3 on the push in then down method and got to keep them lubed. I took and added plug welds on my replacement hood in the vulnerable area prior to paint. Figured it couldn't hurt but still need to be careful
xrcr is offline   Reply With Quote
Old 02-01-2012, 07:16 PM   #8
S10Fan
Old Heap Driver
Re: Hood Fix
Brand new aftermarket hood, new hinges (NOS), new springs, hood tried to kink the first time I went to close it. I added the stiffeners, problem solved. I have an NOS hood in my shed, the difference between the NOS hood and a China hood is amazing. I kept the China hood because it's painted, pinstriped and fixed with the stiffeners.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 02-01-2012, 07:59 PM   #9
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Re: Hood Fix
When I got my new Taiwan hood (dual cowl from LMC) I also got new springs, hinges, and stiffeners. A guy in our car club that does show car quality body work ended up convincing me not to put them on. I don't know if this is true but he said that the crumple in the hood was supposed to be a safety feature in a head on wreck. The hood would crumple instead of flying back into the driver. With the stiffeners, he said that any front on collision would send the hood flying back into me because it wouldn't buckle in the middle (the hood stiffeners are thick).
I'm no expert but that's what I was told and why I didn't put them on. New hinges/springs and a lot of grease keeps mine from warping.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 02-02-2012, 09:10 AM   #10
Keith Seymore
Keith Seymore's Avatar
Re: Hood Fix
This is true - but it doesn't stop many car guys from defeating safety features like crush zones, adding fiberglass bumpers (or removing bumpers), taking the guard rails out of the doors, removing or replacing seat belts, etc.
Myself included.......
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-02-2012, 11:41 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Hood Fix
i thought that cowel post setup was for that,mine is buckled i think from pushing up
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-03-2012, 01:53 AM   #12
allchevy58
allchevy58's Avatar
Re: Hood Fix
Also, spray some WD 40 or lube on hinges. That's why they bend, because hinge gets too stiff.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
