Old 01-31-2012, 11:32 PM   #1
Bartenfeld
Bartenfeld's Avatar
What psi should my radiator cap be rated for???
What radiator cap psi rating is stock for a 66 with a 283?? The 283 was removed, but thats what the truck originally came with. It still has the stock radiator, but the engine has been replaced with a 305. For what reason would you want to run any different psi rating??? They have 7, 13, 16, 18, and 20psi at the local parts store......
Bartenfeld is offline   Reply With Quote
Old 02-01-2012, 01:04 AM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: What psi should my radiator cap be rated for???
Moved ya to engine and drivetrain, someone will chime in.
Alan's Classic is offline   Reply With Quote
Old 02-01-2012, 01:34 AM   #3
storm9c1
*** That's interesting ***
storm9c1's Avatar
13 or 16 psi is usually what I run on all of my vehicles from that era. It's usually the stock value for the brass radiators and a stock system (not sure what year the 7s were used up until). I wouldn't go any higher than 16 unless you have an upgraded cooling system.
I don't know if anyone else discovered this, but if you use the standard Stant cap (and NAPA brand which are rebadged Stants), be careful. I haven't found a 16 psi in two years that actually holds 16 psi. Many failed to build up pressure beyond 5 psi (same application where the 13s worked flawlessly). I found many 16s are made with one less spring now (to save money???) and just don't work right. I've taken a few back and explained this to the parts store guys, who just look at me baffled. The 13s still have the extra spring and they work right. You can physically see the difference when you look at a good and bad 16 side by side (or even compare a 13 to a 16), the missing spring causes the bottom check valve to dangle aimlessly without being pulled up against the rubber seat. Only on the 16s. The ugly (but functional) Lev-R-Vents seem to work fine too.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 02-01-2012, 11:47 AM   #4
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
IIRC (and my brain may be way off on this) each # of pressure raises the boiling point of water something like 3° F, so a 13# cap would keep your system from boiling over 'til it reached 251°. I wouldn't worry about running any thing more than stock. I think I run a 13 on mine. a 7# still gives you 233°. keeps you from boiling over, doesn't cure overheating
storm makes an excellent point about caps holding pressure, they can look fine and not work worth a hoot, as I found out recently when a friend suggested I check the one on my street rod.
Larry
fleetsidelarry is offline   Reply With Quote
Old 02-01-2012, 12:20 PM   #5
fleetsidelarry
Senior Car Nut
And to answer the original question, the '63 service manual says 13# for pickups and the '66 supplement says no change to cooling systems from '63
Larry
Old 02-02-2012, 09:14 PM   #6
Bartenfeld
Bartenfeld's Avatar
Ok, I put a 7# cap on it the other day just to be safe. I guess i'll just keep that one. Any objections? Going off of fleetsidelarry's post, I shouldn't really be getting up to 233 anyways.
Old 02-03-2012, 11:39 PM   #7
storm9c1
storm9c1's Avatar
If a recovery tank was never added, then be sure to check your coolant level often. That 7# is quite low and the cap may release often enough to vent a little steam more often than you think, especially if you put it to work.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 02-03-2012, 11:56 PM   #8
Bartenfeld
Bartenfeld's Avatar
yeah the 7# cap has been releasing a little bit here and there. I think I am gonna step up to the 13# cap.
Old 02-04-2012, 04:56 PM   #9
Warrens69GMC
Warrens69GMC's Avatar
Just FYI, here in AZ I run a 180* thermostat year round, and run a 13lb cap in the summer (runs at 180*) and in winter I run a 16lb cap (runs around 195-200) for more winter heat.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
