Old 02-01-2012, 05:28 PM   #1
KrazyRay
KrazyRay's Avatar
Ram Assist from 68 K10
I pulled this from a 68 4x4, but there were plugs in the ram assist. I believe this to be the rare power steering, but not sure. It does NOT come with the steering box and pitman as it looks like a normal one anyway. $33 shipped.
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 02-01-2012, 08:35 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Ram Assist from 68 K10
I'll take a shot with it. I'll take it.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-01-2012, 08:40 PM   #3
MadnessBigBlock
If VA72C10 passes i will take it!!
MadnessBigBlock is offline   Reply With Quote
Old 02-02-2012, 12:11 AM   #4
KrazyRay
KrazyRay's Avatar
pm sent
Old 02-02-2012, 12:18 AM   #5
VA72C10
VA72C10
VA72C10's Avatar
payment sent. thanks
Old 02-02-2012, 09:36 AM   #6
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Must have been aftermarket unless they redesigned specifically for early 68 which I doubt. Look here for pics of the 67 setup: http://67-72chevytrucks.com/vboard/s...d.php?t=427573
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 02-02-2012, 11:34 AM   #7
VA72C10
VA72C10
VA72C10's Avatar
I figured it was worth a shot even if it was aftermarket...I had checked all the threads on here about the 4wd ram assist and it didn't look like the factory setups I'd seen...
Old 02-02-2012, 11:40 AM   #8
mahanian
C10 addict
mahanian's Avatar
That thing is pretty interesting, there's no ram on it so I don't think it's a power assist, but I'm really curious what it is!
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 02-02-2012, 11:51 AM   #9
Vintage Windmills
Vintage 4x4s
It appears to be the valve that senses steering load and then diverts flow to the appropriate side of the assist ram. Was there an assist cylinder on the truck Ray? Even though its probably aftermarket, I bet the principle is the same. Check out the link I posted.
Old 02-02-2012, 12:14 PM   #10
mahanian
C10 addict
mahanian's Avatar
You are probably right, it just seemed too simplistic of a design to incorporate the appropriate internal valving needed. The ones on my 67 pickups look similar to the link you posted except they are oriented inline with the centerlink for a 2wd.
Either way I think it's cool!
Jared
67 Camaro RS
Old 02-02-2012, 02:31 PM   #11
Vintage Windmills
Vintage 4x4s
Yeah, I thought it looked almost too simple as well but I can't figure out why else there would be 4 ports on there.
Old 02-02-2012, 02:44 PM   #12
ls1nova71
ls1nova71's Avatar
That's a strange piece! Ram assists are generally parallel to the tierod, that piece is IN the drag link! Strange.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-02-2012, 02:51 PM   #13
ls1nova71
ls1nova71's Avatar
The more I think about it, the more I think it wouldn't work as an assist there. If it changed length any at all while turning the wheels it would just make them turn quicker that the steering wheel was turned. Almost has to be a damper or something? I don't know what it is, just throwing it out there.
Old 02-02-2012, 02:54 PM   #14
mahanian
C10 addict
mahanian's Avatar
This would be the control unit, not the ram part that you are thinking about
Jared
67 Camaro RS
Old 02-02-2012, 02:58 PM   #15
ls1nova71
ls1nova71's Avatar
You're probably right, I just reread some other posts that said that. I just always thought they were all one piece. Must be a 4x4 thing.
Old 02-02-2012, 04:07 PM   #16
KrazyRay
KrazyRay's Avatar
I didn't see any other power steering related parts on this truck. This truck was so incomplete and gutted that I didn't bother with a part out thread. I like the idea on the valving as it would sense which direction to move the ram assist.
