Old 02-01-2012, 08:23 PM   #1
3r!c84
Badass
3r!c84's Avatar
Sitting sidwayz
Okay this is a pretty commen problem with these years of trucks the rear sits a little lower on one side looking from the rear. Mine is the drivers side about 1.5 yes the truck is lowerd but it has the same problem at stock height . It only really is like this in the rear. What could I do to fix this ?
Rotate the leaf springs left from right?
Best pic I got with me
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 02-01-2012, 08:51 PM   #2
Taubert83
Taubert83's Avatar
Re: Sitting sidwayz
http://67-72chevytrucks.com/vboard/s...d.php?t=506212
hope this helps
83 Sierra-future mods, frame on resto, 20's, 6.0......
Taubert83 is offline   Reply With Quote
Old 02-01-2012, 09:05 PM   #3
cory d
cory d's Avatar
Re: Sitting sidwayz
get a big engine and accelerate hard, all the time
cory d is offline   Reply With Quote
Old 02-01-2012, 10:26 PM   #4
3r!c84
Badass
3r!c84's Avatar
Re: Sitting sidwayz
Already Got a decent size motor breaking the tires loose is not a problem
-00 Saturn 5spd
1/4:13:90
Old 02-01-2012, 10:42 PM   #5
74 stepside
74 stepside's Avatar
Question Re: Sitting sidwayz
Your rear leafs probably lost there arch. Mine did same thing. I Installed suburban leafs and no more lean. I think because of the rear gas tank verses the side tanks. Does it lean on side of your gas tank?
74 stepside is offline   Reply With Quote
Old 02-01-2012, 11:22 PM   #6
3r!c84
Badass
3r!c84's Avatar
Re: Sitting sidwayz
Yup drivers tank only. Thinking of swapping left to right leaf
-00 Saturn 5spd
1/4:13:90
Old 02-02-2012, 09:14 AM   #7
Keith Seymore
Keith Seymore's Avatar
Re: Sitting sidwayz
...looks fine from where I sit...
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-02-2012, 09:32 AM   #8
3r!c84
Badass
3r!c84's Avatar
Re: Sitting sidwayz
Lol I'll get a better pic this weekend. It's pretty noticeable
-00 Saturn 5spd
1/4:13:90
Old 02-03-2012, 03:32 PM   #9
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: Sitting sidwayz
Mine had the lean pretty bad, passenger side was higher than driver side. After I lowered my truck and replaced the bed (did both at same time) it sits level again. I did shackles/hangers out back and spindles/cut coil up front. So mine had to be either a twisted bed or hangers/shackles being off somehow.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 02-03-2012, 06:09 PM   #10
77BBGMC
77BBGMC's Avatar
Re: Sitting sidwayz
My right side was a lot lower, it was obvious looking at the leaf spring that the arch was not the same as the left. *I was going to get the springs re-arched but took a gamble at the junkyard and purchased one side for $40.00, worked great. *For once I was able to get by with something cheap. *
It's funny how many of these old pickups you see driving around leaning to one side.*
77BBGMC is offline   Reply With Quote
Old 02-06-2012, 12:32 AM   #11
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
Re: Sitting sidwayz
I swapped my leafs from right to left and I'm almost level now
killthewabbit is offline   Reply With Quote
Old 02-06-2012, 06:22 PM   #12
3r!c84
Badass
3r!c84's Avatar
Re: Sitting sidwayz
see
-00 Saturn 5spd
1/4:13:90
Old 02-06-2012, 06:46 PM   #13
ringger14
ringger14's Avatar
Re: Sitting sidwayz
Mine did the same thing. I actually just ordered new leafs for both sides. I already replaced almost the entire suspension so I figured Id just spend the extra coin and call it good.
ringger14 is offline   Reply With Quote
