Cab trim question
Having trouble removing the trim around front and back window including cab trim under back glass. Can someone guide me with some help.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
Roadtrip!
![]() Join Date: Feb 2003
Re: Cab trim question
You need to pull the glass out. The paint divider trim under the back window will snap on/off.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#3 | |
Hmmm that's what I thought too. I thought the chrome only sat in a channel. If the rubber is still somewhat soft you could use a pick and GENTLY slip it out of the rubber?
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
#5 | |
![]() Join Date: Dec 2010
paint divider has little clips behind it and gently with a flat blade screw driver it will pop off |
Thanks for the info as i will be doing this in a few weeks.
ok i see what you all are saying. With window in it presses the chrome in place so it requires the window to come out to release pressure and making it able to slide the chrome out. Thanks guys i will try it tomorrow.
