Muncie m20...where?
My saginaw tranny decided to take a dump. Any recommendations on where to find a new Muncie m20 or a good used one?
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482 Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985 “Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!” - Hunter S. Thompson |
Re: Muncie m20...where?
Several places on the web to buy new or rebuilt M20. Here's one:
http://www.tbtrans.com/muncie_4_speed.htm
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Richmond t-10 will get you where you need to be as well. You can get them new for around 1400-1500.
Id get the 2.88 ratio. I personally think the T-10 is a better option than any of the Muncies because of their new availability and support as well as multiple ratio options. Cost is about the same too unless you go for a used Muncie of which they are vastly more available in the used market.
That's Medium Gold. You just want to see Ochre. |
If you go a for a Muncie look to see if it has the newer style Tork-Loc sliders installed. Virtually eliminates them jumping out of gear.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
ive got a rebuilt one i pulled to do an automatic swap,i have everything.shoot me a pm...im a couple hours away from you.
