02-01-2012, 09:30 PM | #1 |
3 speed OD trans on cl
Pancho 69 c/10 step side 454/400 with 3.07 |
02-01-2012, 09:37 PM | #2 |
Roadtrip!
Re: 3 speed OD trans on cl
Looks like a good buy... Not sure about the 3 speed power glide part!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-01-2012, 09:45 PM | #3 |
Great deal on that 3 speed Powerglide w/ overdrive.
I know something is wrong with that statement somewhere.
That's Medium Gold. You just want to see Ochre. |
02-01-2012, 10:09 PM | #4 |
I think it's a Saginaw 3 speed with a Borg Warner OD unit. The big silver thing is the govoner. Also requires some wiring & I think a manifold vacuum switch to help kick down out of OD when needed.
But it is very reliable when set up. When using the OD between gears with a 3 speed, you get a 6 speed. You can also move the OD to regular 4 speed Saginaw & get an 8 speed. Here's some additional info. http://www.speedprint.com/deves50/doc/bwrebuild.pdf http://www.vcvc.org/showthread.php?1...-Unit-Question. This would be much cooler than the regular old TH 350 or a 700R4 Good Luck! |
02-02-2012, 11:04 AM | #5 |
I think its one of the older Muncie SM 318's with the Borg Warner R10 overdrive. I'm not for sure, but I think most of these have 6 volt solenoids. There are several on Craig's List throughout the country.
The later Saginaw SM326, also with the Borg Warner R10 overdrive are supposed to be stronger tranny's, but they are harder to find. I've been looking for over a year and I finally found one in Pittsburg that I bought last week.
49 Chevy 3100 69 Camaro Acro Sport II Biplane |
02-03-2012, 01:04 AM | #6 |
A member on the 60-66 Board is doing this install right now. Here is a link to the thread. http://67-72chevytrucks.com/vboard/s...d.php?t=506747
02-13-2012, 01:09 PM | #7 |
i hear that them 3 speed trannys with the over drive are hard to find
02-13-2012, 10:17 PM | #8 |
yes, they are.
