chevy runs deep
2005 oil gauge going crazy
okay we changed the oil on my moms 2005 chevy tahoe and now the gauge is going crazy when you drive it stays at 80 and when you press on the gas it drops all the way to zero and would stay there till we slow down like at red light then it will go back up, sometimes it starts beeping saying oil pressure too low, the motor has fresh oil and the oil level is good can anyone help me out on this I think my dad use 10w30 can that cause the pressure switch to go bad
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
![]() Join Date: Sep 2005
Re: 2005 oil gauge going crazy
well it sounds liek you knocked some dirt into the pressure switch, it happends with age and mileage piece of dirt gets knocked loose and flows into the switch. i'd swap back to teh 5 w30 as That is what recommend by Chevy a heavier oil will cause increase wear and decrease in fuel mileage. Alot of people say they swap to a heavier oil cause of mileage to help keep the pressure up, i disagree with this seeing i service a lot fleet trucks ranging from the 4.3-8.1l gm motors some with 400k on them still running 5w30 and still reading 60 psi in oil pressure at idle
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#3 | |
chevy runs deep
