02-01-2012, 10:51 PM | #1 |
3 Speed OD
Just got the trans back from being rebuilt. Now all I have to do is try to get it in I have gotten lots of advice here about that and I am very appreciative for that. I was wondering if anyone has a pic or knows where to get a accelerator kick down switch. I would like to see a pick and then maybe I could fab one up somehow or just get one. I don't even know how they were attached or even where. Up higher on the arm? Was it a button or an actual switch? Let me know fellas! I know you guys got the answer!!!!!!!!!!!!! Oh yea anybody know how to ID the year? Thanks All!
02-02-2012, 10:17 AM | #2 |
Re: 3 Speed OD
JEL 111:
Those trannies are sweet. I have the later model with syncro first and really like it. Here are some links that may have what you are looking for on a switch: http://speedprint.com/deves50/overdriveindex.php http://www.stovebolt.com/ubbthreads/...true#Post68335 http://www.classictruckshop.com/club...cts/how_to.htm http://www.classictruckshop.com/club...5n/rebuild.htm The Stovebolt discussion above has a NAPA switch that someone adapted. I haven't put a kickdown switch on mine for a couple of reasons. I have a Cole Hersey push/pull on/off switch on the dash that I can use to kick out the O/D if I need to (very seldom do, however). The kickdown switch is designed to momentarily ground the coil so that the transmission can "release" the overdrive. I have an HEI on my truck and I didn't want to take a chance with grounding an HEI coil. Hope this helps. Regards, Steve New Orleans |
02-02-2012, 02:30 PM | #3 |
Re: 3 Speed OD
JEL111
What type of transmission is that? Muncie/Saginaw/Borg? Also, on the tailshaft, have you been able to determine what THREE STAMPINGS indicate? Randy |
02-02-2012, 04:53 PM | #4 |
Re: 3 Speed OD
I believe that it is a borg. I haven't been able to date it or figure out what all the numbers mean. I bought it out of the car and got just what you see. I had it rebuilt and the guy added the od arm. I now know, thanks to slorio for the links, that it is configured wrong and i will have to make it right myself. The guy I bought it from and he said it was out of a 57 chevy bel aire.
02-02-2012, 05:12 PM | #5 |
Re: 3 Speed OD
Sept 26, 1957 is your date code, I believe for the tranny main housing. I have a similar one, that I have been trying to identify before seeing your post.
I am still trying to figure out what the codes on the tailhousing unit mean. Also, do you have any notes on the oil seals (side cover) and (rear tailshaft) that were used in your re-build? Source for purchase of these seals? Thanks, Randy |
02-02-2012, 08:20 PM | #6 |
Re: 3 Speed OD
Rd I do not. I will try to find out for you though. I just have to make a call and see where the trans guy I took it to git the gaskets and such. Thanks again for the great info! I think it will help a lot. It is giving me the confidence to take this on myself instead of farming it out. Oh I just scored a OD unit for inside the cab! It is the original (I think) engage thing a ma bob. The cover is broken hopefully I can do something about that to make it better!
02-03-2012, 12:08 AM | #7 |
"Where were you in '62?"
Re: 3 Speed OD
http://www.yearone.com/updatedsingle...nfo/muncie.asp http://www.nastyz28.com/chevy-manual...tification.php ((((Transmission Specs )))) http://67-72chevytrucks.com/vboard/s...d.php?t=390542 1960-1964 rebuilt 1/2 ton 3 speed transmission http://67-72chevytrucks.com/vboard/s...d.php?t=349416
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
02-03-2012, 01:51 AM | #8 |
Re: 3 Speed OD
Damn it'd be sweet to have OD, nice score!. that in cab switch will clean up real nice.
02-03-2012, 05:09 PM | #9 |
Re: 3 Speed OD
Bad it has a 4 bolt side cover> Thanks Dracko
02-03-2012, 10:09 PM | #10 |
Re: 3 Speed OD
I know a guy that took a Saginaw 3-speed overdrive plantery and put it on a saginaw car 4-speed. Works great.He has it in a 57 belair. Makes a world of difference when you are running 456 gears.Google saginaw 4-speed overdrive and it will tell you about it.I think your 7 bolt side plate was the fully syncronized. And the module cap was plastic than metal with the older ones.Newer ones are very tough to come by. GOOD LUCK
