Old 02-01-2012, 11:08 PM   #1
jbgroby
jbgroby's Avatar
Heater control levers
Ok I'm restoring the last of the dash incerts for the truck. Ordered new heater knobs as below.
http://www.classicparts.com/1960-63-...ctinfo/68-464/
And I ordered 1 lever (OEM one was broken) I discovered that the new knobs, are not made to stay on the old OEM levers. Before I order two more lever (and takke all the stuff apart AGAIN. Is there some fitting or clip I can order to make the new knob fit the older levers?
I could put a dab of silicone on them and that woudl work (I could still removed the knobs if needed, just wanted to try and do it correct (Annal sometimes)
Jake
jbgroby is offline   Reply With Quote
Old 02-01-2012, 11:12 PM   #2
awbrown
Re: Heater control levers
I noticed that with mine too , I bought all the levers , silicone if it helps them stay put, is more than likely a better idea than epoxy ...
awbrown is offline   Reply With Quote
Old 02-02-2012, 09:28 AM   #3
1963c-10
1963c-10's Avatar
Ive got a couple of the originals left....which one are you needing?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 02-02-2012, 09:56 AM   #4
jbgroby
jbgroby's Avatar
I have OEM ones, If I chicken out on the silicone, I'll order 2 more new after market (these have raised areas that work with the new levers. Believe this or not, the pain in the butt part is removing the lock/speed nuts. That takes more time than the rest ofthe restore all together.
Jake
Old 02-02-2012, 12:49 PM   #5
1963c-10
1963c-10's Avatar
The only nice thing about the repop levers is that they are not cast pieces. Most of repops Ive seen are cut from a solid piece of metal.
