02-02-2012, 12:13 AM | #1 |
Looking for 35 spline 9" 3.73-4.11 used
I've checked Craigslist, racing junk, and a few others. I cannot find a used fully assembled 9" drop out. I would prefer it was a full spool but a locker would work. Again must be 35 spline. Must be a streetable gear, no high shock load drag only gear alloys. 3.73, 3.90, or 4.11 I would prefer 3.90. (I currently run a 4.56) 1350 yoke only
Do any of you gear heads know where I can find one of these???? No junk please Moser, Strange, or Yukon |
02-02-2012, 12:53 AM | #2 |
It's Better With Nitro
Re: Looking for 35 spline 9" 3.73-4.11 used
That's kind of a unique/tough combination to find without purchasing a new unit from Strange, Mark Williams, etc. Is there a reason you want a hardened gear with a spool? It's not very common to specify a spool without a Pro Gear. I'll keep an eye out though.
02-02-2012, 08:37 AM | #3 |
mini truck racer
I have a new 35 spline Moser spool . It is going to be tough to find a used set up as stated . Most street gears are small pinion . Yellowbullet classifieds would be worth a shot .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
02-02-2012, 11:38 AM | #4 | |
I'll be buying a similar set up next year from Strange probably with a locker and street gears. Its not easy to find that set up used. I think with street gears and a locker they are around $1200 new.
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
02-05-2012, 03:27 PM | #5 |
I know their hard to find, that's kinda why I posted on here. I have $1650 in the set I currently have. Maybe I'll have to bite the bullet and buy another new set in spring. Sounds fun!!!!
Thanks for your Input guys |
