Old 02-02-2012, 12:53 AM   #1
Tony3696
1983 Chevy K20 P/U Reverse Light Problems
I have a 1983 Chevy K20 P/U with manual transmission (3 speed with granny low) and the reverse lights don't work. I checked the bulbs and fuse and they were fine. Is there a position switch and if so where? I need to get this beast inspected, but don't know where to look!
Tony3696 is offline   Reply With Quote
Old 02-02-2012, 03:21 AM   #2
Ken 45LC
Re: 1983 Chevy K20 P/U Reverse Light Problems
On my 83 1 ton with the manual tranny the sensor was on the passengers side of tranny near the top by the shifter. I believe the wire was a lime color, or lime color with a blue stripe. You should be able to see it come out of the firewall near the steering column and then travels along the firewall towards the motor.
I had to replace my sensor because it is in an area that attracts mud and crud and isn't easily cleaned even with a power washer.
Hope this helps,
Ken
Ken 45LC is offline   Reply With Quote
Old 02-02-2012, 05:38 AM   #3
rcbildr
rcbildr's Avatar
I had a similar problem when I had that type of trans in my 85 burb. I discovered if I moved the shifter to one side it would get the lights to come on. I figured roller/button on the switch was worn out.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-05-2012, 11:17 AM   #4
Desert1957
Desert1957's Avatar
Here is the backup light switch mentioned above
Desert
Desert1957 is offline   Reply With Quote
