Old 02-02-2012, 04:45 PM   #1
matchstick
matchstick's Avatar
Swapping from a 1991 Burban front to 78
What all will I need to go this swap? Fenders, hood , grille, radiator support, and bumper. Anything else I will need to know?
matchstick is offline   Reply With Quote
Old 02-02-2012, 05:01 PM   #2
cory d
cory d's Avatar
Re: Swapping from a 1991 Burban front to 78
you have to slot the firewall for the hingess
cory d is offline   Reply With Quote
Old 02-02-2012, 05:01 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
I believe there is a difference in the frame horns too for the mounting of the front bumper.. other than that its pretty easy
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-02-2012, 05:24 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
wipers
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 02-02-2012, 05:58 PM   #5
Prerunner1982
Prerunner1982's Avatar
Funny most people convert to the 91 front end... not many people go the opposite way.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-02-2012, 06:52 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
something to consider some have inside opener,
some outside....hood catch changes with it too
light wire harness,
front side markers,
the newer will fit over the hole for the older but tapered and look weird
fill piece under the grill to the bumper
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-02-2012, 08:18 PM   #7
ghettoluxury
ghettoluxury's Avatar
I did this last summer. You need the entire front clip including the wiring harness. The wiper posts need to be changed as well because the 70's were under the hood and the 80's were above the cowl. The only thing I found that would discourage anyone from this swap was that the top fender bolts on the cowl did not line up. You could weld a piece of metal to it and drill a new hole. I opted to drill the spot welds out of the brackets for both sets of fenders ( since mine were rotted ) and weld the 80's brackets to the 70's fenders.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-02-2012, 08:20 PM   #8
Rogue_Alphonse
Rogue_Alphonse's Avatar
Going from newer to older? You either have to shave the newer bumper at the top corners of the very ends or use the older bumper. Body mounts are different but I combined both to make it work. Need EVERYTHING for the wipers except the motor. Honestly the older wiper track is better. The holes for the posts won't line up but 2 bolts are just as good as 3. Arms... 1980's arms rub under the hood, but work. [I was forced to use the newer ones thanks to Rain-X Latitudes not making adapters... and I love the stainless ones ]
My top fender bolts didn't line up [the ones beside the hood hinges] but you don't need them really...
this was an "instant thought and say" post... there;s a lot I haven't covered but others have or will anyway
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
