What kind of starter are you using??
Are any of you guys using mini starters with the use of headers on your motors and if you, what kind?
Thanks, Mike
The Fleet........ 68' Camaro - 1st car (restored & still have it) 09' VW Tiguan (Wife's Daily Driver) 14' VW Passat SE TSI (my personal) 14' Ford Edge Sport (Daily Work Vehicle) 73' SWB Stepside - 77K org. miles 74' LWB 454/TH400 - drive train transplant for my (Sold) 98' SWB C1500 W/T - shop truck (Sold) 90' GMC Sierra SLE short step - aka " Jezabelle " (Sold) |
Re: What kind of starter are you using??
http://www.summitracing.com/parts/NAL-12361146
what i have, works great, its rebuildable, I needed a new solenoid, I just got the cheapest one of ebay, works great. |
Old Heap Driver
Power Master #9600, I have one on both my 454 and 383. They're pricey but zero failure in 3 years.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
stock on 383 and my sb 400
chevy runs deep
Autozone stock replacement on my 350
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
i use a starter off a 96 up s10 4.3.bolt rite up lot smaller.
I still have what appears to be the original starter and it's yet to fail me.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
Stock, Replaced it last year when I bought the truck, I belive the one I pulled out was the original.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
#9 | |
GoatLube Experss
![]() Join Date: Oct 2009
and I have a Jegs brand mini starter on MonteCarlo. three years of start'n a 20 or so times most every friday night, no problem's .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
GM high torque mini starter on my 454. But I think with headers you may still need some wrap around that starter. I also have a remote solenoid installed, but that is a real touchy issue with some posting here.
On a budget like Fred Sanford
Using a GM factory mini starter for later model vortec 350. I burned up two evilbay tilton style mini starters before I got the GM one and they were both a royal pain to shim correctly. The GM mini bolted right up and was perfect with no shims.....
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
This starter works great with headers and sounds great!
http://www.oreillyauto.com/site/c/de...&keyword=32390
87 Chevy R10 LB 02 Nissan Sentra GXE |
#13 |
Also powermaster #9600, awesome unit on the 454. Also put the same one on my buddy's 69 Nova B.B. he races only, still great even heat soaked.
#14 |
Drag Racer
Zach Hall 1983 Chevy C10 R/T: .194 60': 2.322 330: 6.379 1/8: 9.803 MPH: 71.37 1000: 12.781 1/4: 15.314 MPH: 88.79 |
#15 |
just a stock replacement starter..whatever brand my starter/alternator guy uses
Love My Country, Hate My Government |
#16 |
78K & 79C Jimmys
stock
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#17 |
Just one thing about the gm mini starter (and maybe other mini starters?)- there will be a slight gap visible at the top of the rectangular mounting base of the mini starter because that mounting base is different from the stock mounting base - at least that is the situation with my 83 C20 454 SM465.
#18 |
PowerMaster 9612 (2x) one on 383 and another on 350. If the project budget is tight I go for Skipwhite 3HP-S215K mini-starter with a LIFETIME WARRANTY. All my truck engine builds use stagger mount starters.
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
#19 |
Thanks for all of thre repsonses men but, I am working on a slim budget after having to buy a new daily driver. I am using 153 tooth flywheel on my toy with long tube headers. I guess I may need to get something with a dual bolt pattern just in case I change over to a 168 tooth flywheel and clutch package
#20 |
Resident of Here
83 - NAPA Reman
88 - Stock, will get replaced by a Denso 281-8002 ![]()
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#21 |
#22 |
Chevys Kick A$$
Just stock in all my trucks nothing special. Never had to many issues with them yet really!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
