Old 02-02-2012, 06:44 PM   #1
Atomsplitter
Atomsplitter's Avatar
Welding Rear Crossmember on New Mar-K bed
I was talking to my local parts supplier that I got my new Mar-K bed parts from. He suggested that after the sides were bolted to the rear crossmember that I weld them together!
Anyone else do this or fell its necessary?
Atomsplitter is offline   Reply With Quote
Old 02-02-2012, 07:08 PM   #2
OrrieG
OrrieG's Avatar
Re: Welding Rear Crossmember on New Mar-K bed
My original Fleetside had spot welds between the rear cross sill and sides to help keep the bed sides from moving around when the tail gate is open. I remember grinding them out when I removed mine. Cavet, my truck originally came with a lift gate so it may have been welded after the fact.
OrrieG is offline   Reply With Quote
Old 02-02-2012, 09:40 PM   #3
Atommik
Atommik's Avatar
When I disassembled my original 51 box, it was welded along the edge of the side panel to the rear panel. I'm going to build my own box, so I think I will be welding it up. I don't want the side panels to move in or out, as they may over time if they are only bolted.
Atommik is offline   Reply With Quote
Old 02-02-2012, 10:12 PM   #4
tmoble
my original 57 short stepside was welded along the seams between the rear sill and the sides.
tmoble is offline   Reply With Quote
Old 02-03-2012, 03:15 PM   #5
_Ogre
_Ogre's Avatar
mine's welded
seriously... my original sill was welded too.
shop air compressor timer
Old 02-03-2012, 04:18 PM   #6
youngrodder
youngrodder's Avatar
I welded mine as well, but that was so based on style over substance. I wanted to shave the bolts for a cleaner look. Also since my bed floor needed to be raised to accomidate my frame, I also welded a filler plate to the roll pan to finish the look. I only remaining bolts were for the tail lights and the hindges.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-03-2012, 04:34 PM   #7
oldcouple
oldcouple's Avatar
My 56 was welded, tacked on the ends, but after getting it crushed by a teacher at school, I chose to bolt the new one in just in case she did it again.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 02-03-2012, 05:26 PM   #8
Wvgearhead
That is one sweet truck youngrodder!
Wvgearhead is offline   Reply With Quote
Old 02-03-2012, 07:16 PM   #9
Flames97
Flames97's Avatar
Youngrodder-Did you weld the front panel of the bed also?
That is a sweet truck by the way.
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 02-03-2012, 08:42 PM   #10
OrrieG
OrrieG's Avatar
Front panel does not need it because the sides and end support each other in a 90 degree angle almost full height. Welding the back creates a little mini-moment connection to resist the side top moving laterally.
Old 02-03-2012, 08:55 PM   #11
mknittle
mknittle's Avatar
Originally Posted by _Ogre View Post
mine's welded
yours don't count! Ogre you are just different.
Makes life more interesting don't it though!
mark
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 02-03-2012, 09:04 PM   #12
mknittle
mknittle's Avatar
mark
It really does look nice! i like the idea and the workmanship!
Mark
My GMC build.
Old 02-03-2012, 09:11 PM   #13
mknittle
mknittle's Avatar
Marc
Looks great Marc! is the filler bent toe a 90 degree L shape or is it shaped like the stock sill on top?
Mark
Mark
My GMC build.
Old 02-04-2012, 12:04 AM   #14
youngrodder
Mark
Thanks for the kind words. Mine is not welded in the front. No need as mentioned by OrrieG. Plus with the way my bed mounts are, it would be difficult to remove the bed if the front was also welded.
As for the filler. I started with some thick bar stock welded in place. Then I took some sheet metal to close the gap.
Marc
Old 02-04-2012, 12:19 AM   #15
Flames97
Flames97's Avatar
Thanks OrrieG and Youngrodder for the replies.
-Aaron
