79-93 Mustang R&P Steering
Has anyone replaced there old 74-78 Mustang R&P with a newer 79-93 one? Does it just bolt in? I hear it is less sensitive than the older ones. I have the old rack with a reduced pressure pump on my 54, but it is still too quick for me. Thanks
Re: 79-93 Mustang R&P Steering
i have the newer rack on my my 58.
i'm thinking of putting a ford pump on my truck. maybe a manual rack instead.
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
I have a '94 rack for a SHO. that with a borgeuson kit and steers awesome. its about a turn and a half to lock and has a really good feel.
I don't know which year Mll I have but it is almost 3 turns lock to lock,(2 3/4) it may be out of a T-bird. I did have to trim the ends a bit to fit t-rod ends and get enough toe in.
I also had the Very quick Mll R&P and I like the 2 3/4 one much better
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
I have found one solution. Speedway Motors sells offset bushings part #910-34342 that let you put a 15 1/2" rack in a 16" on center mount and visa versa. No drilling or grinding of the passenger side crossmember hole. I will let you know how it works out. If anyone has used this set up please let me know. Thanks
I did change from the 151/2 to the 16 on the black truck when I upgraded, and I just elongated the passenger side rack mounting bolt hole in the X-member, that was 45,000 miles ago and still going strong!
