exhaust dumping under bed?
I wanna let my exhaust dump underneath the bed before the rear. If doing this, how much harm will it do to the bed?
![]() Join Date: May 2007
Re: exhaust dumping under bed?
Shouldn't hurt the bed but it will cause "drone"
If you use turn downs to point the flow toward the ground no damage will likely occur.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
So none of the emissions will cause the bed to rot out or anything?
It might turn the bottom black (only without turn downs). IMO it would sound way better if it dumped outside.
Not quite the same, but my Jimmy has full duals dumping down before the back axle. Doesn't appear to have any effect on the vehicle itself, but it sure is noisy...
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold |
If you have gravel driveway or dirt anywhere you park, they blow dirt up like crazy, mine are getting changed.......soon.
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
mine dumps right where you want it... I like it... they turn down. I really have not noticed any smell or anything either
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
If you are driving fast enough emissions won't be under there anyway! Somebody has to be the smart a#$
1968 Chevy C/10 LWB V8 ![]() 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
