02-02-2012, 10:59 PM | #1 |
6 lug Rotors?
OK am new to the site.
i have a 1964 chevy c-10 long bed step side. i bought a Porterbuild dropmember and bought spindles for a 73-87. i have a 2.5 drop spindle and have been looking for 6 lug rotors but i have not been able to find it. do they even make it? and if they do can i still run my 1964 chevy stock 6 lug rims? please anyone help. |
02-02-2012, 11:36 PM | #2 |
Re: 6 lug Rotors?
Cpp
02-03-2012, 01:32 AM | #3 |
60-66 Nut
Re: 6 lug Rotors?
Welcome to the forum
You can get the aftermarket 6 lug rotors for the '73-'87 spindles from Classic Performance Products, Early Classic Enterprises, and Performance On Line. No you can not run the original stock wheels with disc brakes.
02-03-2012, 10:51 AM | #4 |
Re: 6 lug Rotors?
ok then do you know what kind or rims will fit when i change to dish brake? that year will fit?
02-03-2012, 11:01 AM | #5 |
Re: 6 lug Rotors?
Go to 71 or later 4x4 rims. They will clear the caliper and you can retain your factory hubcaps ( if using them). If you look left to right.....front view...will have four bumps to hold caps, not three. Middle pic...back has different clearance for caliper. Pic with 63 cap on 74 blazer 4x4 rim. The HD trucks, 4x4 and some vans had them mid-late 70's
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
02-03-2012, 02:54 PM | #6 |
Re: 6 lug Rotors?
So how would i know what rim is for a 4x4? i mean if i was to go to the junkyard and look for these rims, how could i tell?
02-03-2012, 10:31 PM | #7 |
60-66 Nut
Re: 6 lug Rotors?
Look at the middle pic above. The inside of the wheel has a wider, larger diameter ledge on the inside for cleaeance for the caliper. Taka a look at your stock wheels and compare, you will see it.
02-04-2012, 12:47 AM | #8 |
Re: 6 lug Rotors?
will i be able to use the 73-87 truck ralley 6 lug wheels with disc brakes?
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
02-04-2012, 01:11 AM | #9 |
67-72 parts collector,…
Re: 6 lug Rotors?
Yes.
02-04-2012, 09:19 AM | #10 |
Re: 6 lug Rotors?
Yes that's what I plan to run is 73-91 4x4 truck rallies with camaro tall derby caps to hide lug nuts. I will get a pic of what Im talking about looks sharp
Posted via Mobile Device |
02-04-2012, 10:58 AM | #11 |
Re: 6 lug Rotors?
cool i want to see that.
