Old 02-03-2012, 03:19 PM   #1
Handmedown
Handmedown's Avatar
Please help!!!
What is the trick to getting the motor mount bolts started? I give up about ready to have it towed to junk yard, not really but very frustrated Thanks for your help
Handmedown is offline   Reply With Quote
Old 02-03-2012, 03:26 PM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: Please help!!!
More details of what you are doing would help us to help you.
motor in truck, sitting on the crossmember?, which bolts are you trying to start? mount to engine, or mount to perch on crossmemer?
tips like using a smaller diameter bolt to ensure you have holes lined up, or did you clean the treads of the hole and bolt and ensure bolt threads easy..
If you are not able to get the long bolt thru mount and cradle, use floor jack (carefully) to move engine around until holes are lined up....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 02-03-2012, 03:33 PM   #3
Handmedown
Handmedown's Avatar
Re: Please help!!!
putting 350 back in after rebuild 350 tranny still in truck. I got the bell housing bolts in no problem I have the bolts thru mounts into block but not tight I can get the bolt into the mount on pass side but the driver side mount needs to moved down like the motor needs to twist
Old 02-03-2012, 03:45 PM   #4
Old Money
Re: Please help!!!
try loosening mount to frame bolts to allow wiggle room. get pry bar, try a few creative words,lift engine ever so little,send wife and kids away and before you know it it will finally work. i pulled oil pan twice in one week because of cheap gasket.
Old Money is offline   Reply With Quote
Old 02-03-2012, 08:14 PM   #5
Handmedown
Handmedown's Avatar
Re: Please help!!!
So I finally got it bolted in! Then I tried to bolt the flywheel to converter and realized the converter was bound up against fly and had it flexed forward. I hope it didn't bend it. It looks like it went back to straight, sure don't want to have to change it at this point.
Old 02-03-2012, 08:19 PM   #6
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
Re: Please help!!!
Make sure that converter is all the way in!
Did you turn the converter onto the trans all the way in ?
JOHNORO is offline   Reply With Quote
Old 02-03-2012, 08:45 PM   #7
Handmedown
Handmedown's Avatar
Re: Please help!!!
I'm pretty sure the converter is all the way on , do you think I damaged the flywheel
Old 02-03-2012, 08:51 PM   #8
terry b
terry b's Avatar
Re: Please help!!!
I would be more worried about the pump on the trans. If that converter is not all the way back you might have just screwed the pump up.
terry b is offline   Reply With Quote
Old 02-04-2012, 09:44 PM   #9
rkn463
rkn463's Avatar
Re: Please help!!!
Terry B is correct, tightening the motor down without the converter properly engaged can break the front pump (I've done it ) When putting the converter on it has multiple engagement points, the last one is the two slots on the snout of the converter (the bit that the seal rides against). After making the initial stab just slowly rotate the converter while pressing in on it and it will clunk in about another 1/4 to 1/2 inch. No worries about the flexplate that I am aware of.
Also if you dont want to pull the whole thing back out to seat the converter get a couple of bolts about 4 inches long and thread them in the bottom two engine to trans holes, remove the rest, unbolt the rear trans mount and slide the trans back to gain enough space to spin the converter. I've done this on several cars I expect it would work on the trucks as well.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
