Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-03-2012, 08:19 PM   #1
jeboblasto
Jacking up truck on dry soil!?
Hey there, i have been trying to find some info about what my options are for doing some suspension work where it's parked, which is on grass/dirt. There's a pretty level spot there and it is packed down pretty good, once it's dried out a bit. I am considering the safety of working on it there, rather than trying to find a shop or paved driveway. Just wanted to know if anybody has experience, any recommendations for this type of scenario. My 67 needs back on the road, been biking all winter. Pouring concrete is not an option, i was leaning in the direction of a concrete rv type pad/block or two. Thanks,
jeboblasto is offline   Reply With Quote
Old 02-03-2012, 08:41 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Jacking up truck on dry soil!?
I think I'd be out looking for someone sawing up a big tree.
Big logs under frame?
ETsC10 is offline   Reply With Quote
Old 02-03-2012, 08:44 PM   #3
Sillyoldman
#16876
Sillyoldman's Avatar
You took the words right out of my mouth. I usually put a wood round or two under the frame ever since I had that jeep fall on me.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 02-03-2012, 09:17 PM   #4
donut
donut's Avatar
Hard packed like clay? Or is it more like a section of lawn?
In my dirt driveways, I'll use 3/4 plywood sections sitting FLAT for jacking and jack stands. Logs or cut timbers for frame bracing/cribbing. Do as much with the wheels on the ground as possible. Try not to get under it. (sorry if it seems obvious, but some folks consider cinder blocks as "safe". Like the guy up the road, my neighbor and...)
I have used small concrete RV pads, if you have to move them, it can be a chore.
If you don't like the looks of something, correct it. It's far easier to do it correct than pick the truck up off the ground and start over, much easier than if your next of kin get to finish your project.
I work on vehicles far more on dirt than pavement.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 02-03-2012, 10:03 PM   #5
yousesteers
Get you some oak or a hardwood blocks.
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 02-03-2012, 10:37 PM   #6
jeboblasto
It's lawn, dirt, been parking on it for a fair while. I would wait for some warm/dry weather for sure. I may have a line on some free big logs that would work, might get a pad as well, just to have a firmer spot for the jack. thanks for the perspective. safety is #1 for sure.
Old 02-04-2012, 10:53 AM   #7
donut
donut's Avatar
If you've been parking on it for a while, your that much ahead of the game. My old 4x4 was rebuilt in a section of lawn that my wife and I had been parking on for a couple of years. I even had a large tree root sticking up that made a great wheel chock.
I also burned wood, so I had a fairly large selection of logs to choose from. There was a sawmill locally that used to sell scrap for kindling. I just happened to find a selection of 12x12x24, 6x12 timber cuts from some crane mats they were building for a local contractor.
Old 02-04-2012, 01:01 PM   #8
Restrorob
The One And Only !!!
Restrorob's Avatar
Same thing I use, Then slide the tires up under the frame as well if I have to take them off for the job at hand.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-16-2012, 11:35 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
don't use cinder blocks
older ones were poured into a form
newer ones are pressured into a form
but still they can crack,and drop
i have a bunch of 6X6 and 8X8 chunks for chocks and lifting/support
depending on what you are doing,i have dug under the car "a pit",
enough to slide under it,and not actually lift it
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-19-2012, 03:29 AM   #10
jitteryguy
GoatLube Experss
jitteryguy's Avatar
three quarter ply wood works good and will support jackstands, get a whole sheet and then ya have a solid surface to work on.
stay away from concrete blocks, they WILL bust !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 02-22-2012, 10:33 AM   #11
Chris4x4Gill2
I'll echo what everyone else has said - wood under the jack stands / jack and then some type of safty support under the frame - logs , tires, something to keep it from hittign the ground if it comes off the stands
"Lifetime" 72 C10 Project
Chris4x4Gill2 is offline   Reply With Quote
Old 02-22-2012, 11:33 AM   #12
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Originally Posted by jitteryguy View Post
... stay away from concrete blocks, they WILL bust !
Worth Repeating! Hollow cinder blocks are fragile!
Old 02-22-2012, 08:51 PM   #13
Altec
Getcha Pull
Altec's Avatar
Build these tall enough to get the frame off the ground!
http://www.myturbodiesel.com/1000q/multi/wood-block.htm
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 02-24-2012, 10:50 PM   #14
Sub-versive
Boss Hogg
Sub-versive's Avatar
In my dirt driveways, I'll use 3/4 plywood sections sitting FLAT for jacking and jack stands. Logs or cut timbers for frame bracing/cribbing. Do as much with the wheels on the ground as possible. Try not to get under it. I have used small concrete RV pads, if you have to move them, it can be a chore.
I grew up on a small farm with gravel driveways. We always used 3/4" ply down first, jacked up and used 4x cribbing. My dad drilled my brain about always using cribbing or jack stands.
This saved me from injury. A hydraulic jack failure dropped my truck. If I didn't have cribbing it might have killed me.
Some people might say wood is not safe. I say BS
Wood cribbing is used in heavy construction and machinery moving. It is an economical means of safely(if done properly) carrying a load.
RIP El Jay
2015 Subaru Outback 3.6R Limited
2002 Chevy Trailblazer LS 2WD
Originally Posted by dammitmitchell View Post
....wear your adult diaper when you go out to play.
Originally Posted by Shane View Post
I am tard.
Do, or do not, there is no try
Sub-versive is offline   Reply With Quote
Old 02-25-2012, 10:28 AM   #15
donut
donut's Avatar
I've worked heavy construction most of my life, I learned early the value of cribbing. Also how weak cinder blocks really are, unless used as intended.
Old 02-25-2012, 01:32 PM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I've also found a Jackstand made from 2 wheels to work well on packed dirt.Lay one down and stand the other up inside it.Then weld them together in that configuration.They should still be on a plywood base on dirt but they have a larger base which helps spread the load.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-01-2012, 11:08 PM   #17
Turkey
Turkey's Avatar
look for some rail road ties. You can find 'em cheap from landscape places. cut them up and stack 'em
Turkey is offline   Reply With Quote
Old 03-02-2012, 11:21 PM   #18
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Old 03-05-2012, 11:18 PM   #19
crushermechanic
crushermechanic's Avatar
i use cribbing on a daily basis. it can support serious weight if done correctly. whatever you do do not use pine for cribing. it will crack and splinter. use only a good hardwood like oak or hickory.
crushermechanic is offline   Reply With Quote
