02-03-2012, 08:37 PM | #1 |
C14 or C17 Pedal Rod Booster
I can't get an answer from the parts stores on the proper booster for my 1983 C20.
The options are: Pedal Rod #C14 - GM Code JB6 Brake (7200 LB.) Option Codes are Located on the "GM Service Parts Identification" Sticker Pedal Rod #C17 - GM Code JB7 Brake (8400 LB.) Option Codes are Located on the "GM Service Parts Identification" Sticker I don't have a GM Service Parts Identification Sticker, so which one is correct for my truck? How would I tell the difference? I don't see any markings on the booster or pedal rod itself. I do have a cast iron master cylinder, if that makes any difference. Thanks. |
02-03-2012, 08:53 PM | #2 |
Moderator
Re: C14 or C17 Pedal Rod Booster
JB6 = LD 3/4ton
JB7 = HD 3/4ton JB6 should have 11 5/32" X 2 3/4" drum. JB7 should have 13" x 2 1/2" drum. |
02-03-2012, 09:00 PM | #3 |
Thanks. I guess I will have to pull off a rear wheel tomorrow and measure the drums.
02-04-2012, 04:26 AM | #4 |
I just remembered that I have a floating rear axle. LMC refers to 11" and 11-5/32" brake shoes. Can I determine which shoes I have by looking at the outside of the drum? My VIN has a 4th character "G", which is supposed to be 8001-9000 GVW (VIN tag says 8600 GVW).
02-04-2012, 01:04 PM | #5 |
I finally found it. A very faint stamped "C17" on the pedal rod at the booster end of the rod. What a search.
