Old 02-03-2012, 11:35 PM   #1
saskgreen
saskgreen's Avatar
Transmission Swap question
Hey guys, I am sure this has been talked about lots before so perhaps a link or just info would be good. I currently have a sbc and a 3 on the tree. Looking to put in a rebuilt sbc and a different transmission. Looking at a TH350 or TH400.
Are either one of these a direct swap? I have the two piece drive shaft. Anything you would beef up on those transmission's prior to putting it in? Looking for basic install without to much modifications. Will be on a budget so figured one of those would be best, sure a 6 speed would be cool, but I believe the price goes up lol
Thanks in advance.
saskgreen is offline   Reply With Quote
Old 02-04-2012, 07:44 AM   #2
earlthegoat2
earlthegoat2's Avatar
Re: Transmission Swap question
You are going to want a TH350 most likely as they are available in the same length as your 3 speed so you wont have to change driveshaft length. Im not sure what size of tailshaft you are going to need though. Someone else will know.
By nature a manual to auto swap takes a few modifications. You need a trans cooler and you need to run and mount trans cooler lines from where you mount the cooler (in front of the radiator) back to the trans. Then you need a new steering column for a column shift (which would be my preference) or you can just take the shifter lever off your column and install a floor shifter.
Another thing to note: If the price is right, a Powerglide can also be a mighty fine transmission. The prices around me for them are pretty high though because dirt track racing is popular around here.
That's Medium Gold. You just want to see Ochre.
earlthegoat2 is offline   Reply With Quote
Old 02-04-2012, 01:54 PM   #3
saskgreen
saskgreen's Avatar
Guess I should add it is a long box aswell. What are the lengths that TH350's come in, which one would allow me to keep my driveshaft?
Old 02-04-2012, 10:44 PM   #4
packsand
If you want you can call me...I just did this to my truck and just put it back on the road...it is a very easy swap....208-941-5962...wayne...the 3 on the tree was the worst...and i just did power steering also..http://67-72chevytrucks.com/vboard/a...1&d=1328409793
packsand is offline   Reply With Quote
