![]() Join Date: Jul 2011
thought Id share my day...
I ran all my wires for my system today. Everything new. (deck wires, power wires, speaker wires, new grounds)
everything was full runs (no splices) testing along the way... I had already put down all my sound mat.. and I didn't want to feel any of the wires under the carpet.. so a aluminum taped all the wires down.. (again testing wires all along) then the carpet went in (glued down) I get the deck hooked up, I get the 4 channel amp hooked up, got the speakers hooked up. the 2 channel didn't get hooked up yet so I had the set of RCA going to it then I'm going to use the RCA out to run to the 4 channel. but since I didn't hook up the 2 channel I just connected the two RCAs with female to female barrels. plugged in the fuse, threw a CD in and only two speakers worked........ I spent about and hour checking all the wires and fuses with some cussing and throwing things.. I started to worry that something was wrong under the carpet... I damn near gave up... is the amp bad? last thing I checked was the barrel connecter I used... one was shot... fell apart when I unplugged it.. swapped it out and everything worked great.... and that was my day....
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy? |
needs more $$$
Re: thought Id share my day...
Haha! I'm happy for you that you checked the barrel before ripping up the carpet!
Got pics of the install?
1970 2wd Blazer |
#3 | |
I forgot to take pics, but most of it isn't done anyway.. the wires for the 2 channel are in place but not hooked up.. (sub box not built yet) the back 6x9's are also going into the box... I was able to snap a pic to KINDA so under the seat.. my 4 channel and cap: ![]() .
needs more $$$
Nice! Looks like where I just mounted my 4 channel...
1970 2wd Blazer |
Chevys Kick A$$
Wow that's pretty crazy I never would have guess that would have been the problem haha! Glad it was an easy fix, looks good in the one picture cant wait to see it when its all done.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
BAM.... door panels and front speakers are in...
needs more $$$
Looks great!!!
1970 2wd Blazer |
nice door panels, were they custom made?
thanks, they are factory panels that I had covered.
