Old 02-04-2012, 09:03 AM   #1
trev1
Exclamation Door seal/window rubber question
I am installing all new rubber/seals today for the doors/wing windows/glass runners etc... they are thr glue in type. What should I use to do this.????
Any ideas? Whats the best to use? Only want to do it once!!!!
I know it's been covered somewhere, but couldn't find it.
trev1 is offline   Reply With Quote
Old 02-04-2012, 09:09 AM   #2
chevy88
chevy88's Avatar
Re: Door seal/window rubber question
Lmc truck sells rubber weatherstrip adhesive, or any auto parts store dont use anything else as it is the best.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 02-04-2012, 10:04 AM   #3
Sammy
Think about using some small clamps to hold the seal in place. Used wood clothes pins in the past with some success. I'm sure others may have found other things. When buying the 3 M adhesive use the black not the yellow you will get a better looking finished look.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 02-04-2012, 08:09 PM   #4
trev1
Thanks, I bought the 3M Black Super weatherstrip adhesive. Planned on using masking tape, and will try the clothespins. Sounds like a great idea.
Thanks again.
Trevor
