Old 02-04-2012, 01:31 PM   #1
Fan2zee
Fan2zee's Avatar
From Ignition Switch - Wire - to the Starter
On my TBI 87 R10, I'm trying to run a kill switch. I want to splice into the wire between the Ignition Switch and Starter.
If anyone has a descriptive picture that would point to this wire.
Or know of another wire I can splice into to run the kill switch..
** All to slow down an unwanted theif trying to hot-wire the truck **
87' R10
Fan2zee is offline   Reply With Quote
Old 02-04-2012, 02:06 PM   #2
ozark
Re: From Ignition Switch - Wire - to the Starter
wire that is on small terminal on the starter
ozark is offline   Reply With Quote
Old 02-04-2012, 03:15 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
coil wire .....flooding slows them down too lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-02-2012, 04:02 PM   #4
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
i had a switch on my electric fuel pump on my 88...ain't gettin far without fuel, and there are tons of places to hide it.
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 06-02-2012, 09:47 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
just put switch on HEI dist wire, close to firewall for easy cab access
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 06-02-2012, 10:49 PM   #6
Firebirdjones
If you want to disable the starter, use the purple wire to "S" terminal. It's easiest to grab it at the starter rather than unravel wiring harness under the dash.
Another way to kill the starter is the purple wire at the neutral safety switch, more involved with an automatic, but it's a piece of cake with a manual trans
If you just want to kill the ignition, Use the 12 volt source wire at the distributor for HEI, or use the positive terminal on the coil if you have points.
If you have an electric fuel pump a kill switch for that is a good theft deterent.
I use both fuel and ignition methods (more than one) on a car with a key switch source, so even if the switch is found, it will take a key to operate it Simple toggle switches just aren't enough in my opinion. Hope that helps.
Firebirdjones is offline   Reply With Quote
Old 06-02-2012, 11:59 PM   #7
Mr-Jack
Mr-Jack's Avatar
JB is that you?
Old 06-03-2012, 07:56 AM   #8
88Jimmy4x4
88Jimmy4x4's Avatar
Originally Posted by Mr-Jack View Post
JB is that you?
yes sir
1991 GMC Jimmy 4x4
Old 06-03-2012, 09:24 AM   #9
Laser145
good info!
1987 R10
1976 K10
Laser145 is offline   Reply With Quote
Old 06-03-2012, 01:29 PM   #10
Mr-Jack
Mr-Jack's Avatar
yes sir
I knew from your Avatar...long time bro...heard you bought a lowrider and pimped it out a while back. I don't go by Loki anymore
Old 06-03-2012, 06:33 PM   #11
88Jimmy4x4
88Jimmy4x4's Avatar
oh snap Loki.......my latest project is a 76 GMC 2wd resto
1991 GMC Jimmy 4x4
Old 06-03-2012, 07:40 PM   #12
Mr-Jack
Mr-Jack's Avatar
nice...mines a 67 gmc k10 build (restore after my house w/shop closes) link in the signature
just sold my 88 farm truck and my 84 k5 blazer...looking for a nice tow rig currently small world bud
