02-04-2012, 02:42 PM | #1 |
86 scottsdale sm465 tranny noise
hey guys i just got my truck inspected and the first day on the road it was fine for about 15 minutes then all of a sudden when i let off the gas it makes a loud howling noise it only happens when i let off the gas but if i push in the clutch it goes away. i checked the clutch fluid and tranny fluid and theyre fine. can it be the clutch, pressure plate or throw out bearing? or maybe even the transfercase? im pretty sure the s clutch , pressure plate and t.o.b are stock. when i did a engine swap in 08 we did not change any of them because they looked great. i can't debunk what the noise is and i dont want to rip everything apart yet with out knowing exactly what it is any help would be greatly appreciated thanks
Love My Country, Hate My Government |
02-04-2012, 04:01 PM | #2 |
Re: 86 scottsdale sm465 tranny noise
anyoneee?
02-04-2012, 05:00 PM | #3 |
Could be rear axle as well; axle whine can occur on drive, float, or coast.
Make sure it's not coming from the axle before you start tearing into the trans (which seems less likely to me). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-04-2012, 05:24 PM | #4 |
x2 on the rear end, especially on the 10 bolts like in your 86 if its a half ton, we have a 86 4x4 with 700r4 and the rear end howls really bad when your on the gas but goes away as soon as you let off the gas.
02-04-2012, 05:41 PM | #5 |
yup theyre 10 bolts with 3.08 gears. it only makes the noise when i let off the the gas and then if i push in the clutch it goes away so thats what had me thinking it might be something in the tranny or tcase. but i still need to check the rear and front diffs out anyway. 2 nights ago was the first time the truck was driven on the road since like 2001 so im just finding more things out now. the last thing i wanna do is pull the engine and tranny again and if its the rears my friend has a set of 8lugs with 4.10 gears that ill pick up. thanks for the answers ill check out the rears tommarow when i do the brakes
02-04-2012, 05:47 PM | #6 |
Could throwout bearing.
mine did that |
02-04-2012, 06:28 PM | #7 |
when you shove the clutch it takes thes strain off the rear end and it stops howling.. if it was a throwvout bearing i would think it would do it all the time with the clutch out. even in neautral.
Posted via Mobile Device |
02-04-2012, 06:30 PM | #8 |
mine does the same thing how long till it goes lol?
02-04-2012, 06:34 PM | #9 |
haha. all depends. thats rear end number 2 in that truck alone. not to mention how many my 84 scottsdale street truck has ate.. if you dont poubd it to bad it will last quite a while. its just the gears notvmeshing quite right. the issue with mine is the pinion has slack in it and its not shimmed quite right.
02-05-2012, 09:40 AM | #10 |
my 81 C30 does THE EXACT SAME THING finaly im not the only one, i have the same transmission and whenever i let the fuel off no matther in witch gear (noise increase depending in what gear its in). i suspect internal tranny bearings are shot it has 225 000+km and there are no synchros left what so ever gotta match rev or it wont shift at all. i gave up on finding where its from i drove it a full year like that and now it became a donor truck
02-05-2012, 05:16 PM | #11 |
dam i hope its not the tranny bearings hopefully its the rear end..alot easies to swap out and find then one of these trannys
02-07-2012, 05:01 PM | #12 |
hahahaha im a dumbass..i was so excited to drive my truck since it finally had a inspection that i forgot to check all my fluids like i should have and my rear diff was bone dry..atleast i know to check everything next time instead of pulling my hair out trying to figure out what the noise is..thanks for all the responses though i apreciate them
02-07-2012, 07:30 PM | #13 | |
02-08-2012, 01:07 AM | #14 |
At least you didn't drive it too much and kill the rear end!!
1981 K10 Scottsdale
305 ci | TH350 | NP208 | 60k miles |
02-08-2012, 04:00 AM | #15 |
i still would replace the axel with your friends just for the gears 3.08 suck so bad. they are all a stronger axle for you, you already put two rear end in there so you may want to put a stronger on in there for you.
