02-04-2012, 07:16 PM | #1 |
Help ID factory aluminum 2WD rims
Hi , I get so much great info here and need some help I can't seem to find on my own
I just bought 4 aluminum 5 bolt rims I am thinking they are factory 80's?? as they match some pics I have seen here and the stock center caps bolt to them Inside the rims it says "modern wheel 15 x 6.5 JJ" Anybody know, thanks Last edited by chronos; 02-04-2012 at 07:17 PM. Reason: spelling |
02-04-2012, 09:07 PM | #2 |
Re: Help ID factory aluminum 2WD rims
They probably are but we need pics
1949 Five Window, 1973 Step Side, 2000 Z71 |
02-04-2012, 10:00 PM | #3 |
The One And Only !!!
Welcome Aboard !
As ghettoluxury mentioned ^^^^^^ Pics are worth a thousand words/numbers.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
02-04-2012, 10:08 PM | #4 |
Getting Old; Going Broke
Look like this?
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
02-04-2012, 10:13 PM | #5 |
The rims above are factory.
02-04-2012, 10:28 PM | #6 |
Yes, yes they are. You can find and know the RPO code if you want. At least I think they probably came on it factory, it was a conversion 'burban.
02-04-2012, 11:24 PM | #7 |
Thanks , I am attaching a pic of my rim
It does not seem as 'concave' as the other one posted? Also stamped 'Made in the USA' on the inside....very cool |
02-05-2012, 10:53 AM | #8 |
Will a 31x10.5 tire work on these rims??
Didn't realize that they would only be a 6.5" wide rim? Seems pretty skinny for a 80's era pickup |
02-05-2012, 11:22 AM | #9 | |
Desert |
02-05-2012, 02:38 PM | #10 |
Maybe those are van wheels? I know the rally wheels for van were 6.5 wide while the truck wheels came in 7 or 8 inch. That would explain why the don't look as concave.
02-05-2012, 04:54 PM | #11 |
78K & 79C Jimmys
89 burb wheels here....
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
02-05-2012, 05:29 PM | #12 |
Maybe they are the van wheels. I am just going by what is stamped inside each wheel.
Could even be 'old aftermaket' as they are stamped 'made in USA' I was always thinking they would be at least 7" wide as I am wanting to run 31" tires on them I think best to start a new thread on that |
02-05-2012, 06:19 PM | #13 |
The van 8 hole aluminum wheels were 6.5's and the trucks/suburbans 8 hole aluminum wheels were 7's. Even the K5's and 4x4 squares with the 8 hole (6 lug) aluminum wheels were 7's.
Those are factory wheels you pictured chronos, not aftermarkets.
02-05-2012, 06:42 PM | #14 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-05-2012, 10:45 PM | #15 |
You should be ok. I have ran 15" wide 35's on an 8" wide rim with no problems.
02-09-2012, 03:33 PM | #16 |
Thanks for all the info !
Looks like i have factory VAN aluminum rims Now to get my tires |
