Truck stumbles and almost dies after carb rebuild
69 Chevy 307. It had a two barrel and ran fine. In a fit of being adventurous I bought a performer manifold and rebuilt a old Holley 600 CFM barrel. vacuum secondary.
Truck had new plug wires and HEI before the 4 barrel installation. Runs smooth at idle but when you try to accelerate, even mildly, it backfires and almost dies. When it does pick back runs fine. Cant imagine it is timing. Checked timing and it is 4 BTDC. Must be carb. Where do I start looking? Posted via Mobile Device Posted via Mobile Device |
Re: Truck stumbles and almost dies after carb rebuild
It's timing!! Try 12 degrees. Set it with the vacuum line to the distributor plugged.
Really! I will give it a try tomorrow
Make sure your accel. pump is working good. With the engine off, look in the carb & work the throttle linkage. 2 squirts of gas should come out the nozzles each time. I agree a little more timing might help but I think you have a carb problem. Did you check the float levels after you installed & ran it. The level of the gas should be at the bottom of the plugs on the side of the bowls. You can adjust the level with the adjs. on top of the bowls.
#6 | |
I will double check the accelerator pump tomorrow. Think I have the floats set right
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Agree with the accelerator pump adustment. I would start there first.
As soon as the throttle is moved it should begin to squart gas in the carb. |
1969 Custom 30 wrecker
I would check for major vacuum leaks first, probably at the carb base. With it running, spray carb cleaner around the carb base and even along the intake runners. If it picks up idle speed when you spray, you found a leak.
I'm not familiar with Holleys but if it's a square bore base, you might need an adaptor plate if going to a spreadbore intake.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
| Bookmarks |
