02-04-2012, 09:13 PM | #1 |
left hand or right hand fuel tank brackets?
Was wondeing if there is a difference in brackets for left or right fuel tanks?
I have three sets of brackets that I have located in my collection of stuff, some from trucks I took apart and some from bought projects, but they all seem to be similar pairs. Seems the front to back on the tank seem to be different, or am I mixing up parts, as I have one about two inches longer then the other, but I figured the brackets from the front to the back on the same tank are different. Anyone know for sure???? Thanks,
'70 Malibu with 383 stroker/T350 '56 SWB Mercury pickup..under construction '67 Firebird Convertible...all done stock '70 LWB 350 on propane...beater '69 LWB 350/T400 body restored |
02-04-2012, 09:20 PM | #2 |
Re: left hand or right hand fuel tank brackets?
I forget what the whole process was, but I've made LH into RH and then back into LH again, for 12 and 15 gallon tanks. All the holes for the different tank sizes and positions should be in the frame.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
02-04-2012, 09:41 PM | #3 |
The One And Only !!!
Yep, Their the same. I swapped mine from right to left when I replaced beds, The short bracket goes toward the front of the truck and the long to the rear....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
02-04-2012, 10:45 PM | #4 |
There is a difference in the brackets. The rear ones are the same, but the bolt pattern on the front ones are a mirror image of each other. They will still work because GM stamped holes for all applications. The welded nuts are what make them different. I have sold a hundred of these on the parts board. Another difference is that the later brackets had provisions to mount the plastic tank protector. Those protectors actually held in the road debris which rubbed the tanks raw until they leaked.
02-04-2012, 11:46 PM | #5 |
Thanks for the replies.
Forgot to ask what you are using for protection between the straps and the tank? All the old material is shot, and the new straps I bought don't come with anything.
02-05-2012, 01:26 AM | #6 |
I installed plain old roofing tar paper between the strap and the tank~works great!
02-05-2012, 01:38 AM | #7 |
Bicycle inner tube works well also.
CHEVY ONLY |
02-05-2012, 10:45 AM | #8 |
I used an old inner tube cut down to the width of the strap
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
02-06-2012, 02:01 PM | #9 |
Roofing felt is the closest match to the original stuff that I've seen. The best part is that it's cheap. I of course didn't have any laying around & had to buy a $15 roll of it at Lowe's...cost was around $15. I figure I could insulate a couple thousand more gas tanks with the remainder. Literally.
Jel |
02-06-2012, 08:53 PM | #10 |
I go to heavy truck parts supply and get the rubber material used on big trucks saddle tanks. Almost the same size straps. Looks really good too and lasts longer than the original.
