Tires and wheels for a 49
Ok, I hope this isn't a dumb question and everyone doen't laugh at me for asking
![]() ![]() ![]() Here's what it looks like now. |
Re: Tires and wheels for a 49
If i were you i would try and keep the stock frame unless it's bent or rusted... but to answer your question you can get at least an 8" rim under the rear but you have a 6 lug bolt patten now so i don't if you can find a cool looking rim..
I saw these and I think this is original frame. Do you think? Looks like it is 6 lug. I will have to see if I can find more info
Yes i would say that's a stock frame.. and i was wrong about getting some nice rims in 6 lugs... My friend owns Wheel Smith and he can make just about any rim...
#5 | |
If you don't want to spend much get a set of later model 15 inch steelies paint them nice and put some small hubcaps on them. You can still find six lug rally wheels pretty reasonable and they look good on just about every GM truck no matter what the year. The scrap prices have taken a severe tole on the availability of used aluminum wheels around here but they still can be found. Sometimes a tire store has a take off set or repo set in the back room that they will cut a deal on and there is always the finding them at a yard sale thing. |
#6 | |
If you don't want to spend much get a set of later model 15 inch steelies paint them nice and put some small hubcaps on them. You can still find six lug rally wheels pretty reasonable and they look good on just about every GM truck no matter what the year. The scrap prices have taken a severe tole on the availability of used aluminum wheels around here but they still can be found. Sometimes a tire store has a take off set or repo set in the back room that they will cut a deal on and there is always the finding them at a yard sale thing. I'm another one who doesn't arbitrarily advocate pulling the stock frame and Sticking and S10 frame under the truck just because the other guys are doing it. If the stock frame is in good shape, not bent and hasn't been hacked on for off the wall engine swaps I'd say keep it and put an independent front end under it and an open drive rear end under the back. Check the threads where the guys on here have put Jag front ends under the AD trucks. Not any more expensive than an S10 swap with the current going price of dead S10 pickups and a lot simpler. |
and a few others
Around here there are always tons of 6-lug wheels on Craigslist.
Someone correct me if I'm wrong, but I think all 6-lug wheels are the same bolt pattern. You'll just have to check the backspacing. I doubt stock Toyota wheels would work because they have a massive backspace. Even if they did fit, they wouldn't look right.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
#8 | |
Ouch! mr48chevy! "It doesn't matter what those wheels are on they always scream "I settled for the cheap ones" when I see them on a vehicle. Around here they are what the tire stores sell guys who don't have enough credit or cash to buy the nicer wheels"
I kinda liked those wheels. But, then again as you can tell :-), I don't know much. |
"I'm another one who doesn't arbitrarily advocate pulling the stock frame and Sticking and S10 frame under the truck just because the other guys are doing it. If the stock frame is in good shape, not bent and hasn't been hacked on for off the wall engine swaps I'd say keep it and put an independent front end under it and an open drive rear end under the back.
Check the threads where the guys on here have put Jag front ends under the AD trucks. Not any more expensive than an S10 swap with the current going price of dead S10 pickups and a lot simpler. " So, mr48chevy, this being said- what I want is to lower my truck some, I just like the look (not totally on the ground), and just have better handeling, brakes , etc. I was told by someone to swap to an s10 frame to get this. So, I don't have to do that? Last edited by Rudoo; 02-05-2012 at 10:38 PM. |
You know, I was just looking at my tires on my truck. They look like tractor tires! :-)
what about these. are they affordable? or just cheap
#13 |
I still have a set of those from my stock 78 silverado but they are 5 lug, very good wheels and a nice upgrade!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#14 | |
#15 |
Hey Rudoo,
I have these same wheels (different center caps) on my truck at the moment and my suspension is still completely stock so you can see how low it sits without the tall "tractor" tires on it. An IFS and some drop spindles could get you even closer to the ground with out having to do a whole frame swap. That is what I have been thinking about doing. ![]() |
#16 |
Thanks! Now I'm off to find out what an IFS is. :-)
Love your patina by the way! |
#17 | |
and a few others
Last time I checked, back before OldSub died, there were several starting them or considering it, but I don't remember anyone actually completing it. I've seen a couple cars with Jag IFS on the Hamb.
#18 | |
and a few others
I was hoping someone would chime in; "sure, here's a couple here" I just haven't seen one.
