Old 02-04-2012, 11:58 PM   #1
sigshooter
sigshooter's Avatar
Painted my M/C with Eastwood Brake Gray
I blasted and painted my mstercylinder with Eastwoods Brake Gray, so far I love it. Looks nice, my M/C wasn't very old but rusted quickly and looked terrible. I took it apart blasted it in a cabinet, prepped it and shot it with Brake Gray. Looks great, doesn't look like paint still shows all the pores of the cast metal. Covered well also. So Far I highly recomend this product, We will see how it holds up over time. I am going to spray my drums and power gearbox with the rest of the can, If I have enough I will do my front hubs also.
I am going to do my exhaust manifold next with Eastwood Factory Gray manifold paint ( I bought it at the same time as the Brake Gray )
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 02-05-2012, 06:45 AM   #2
darkhorse970
darkhorse970's Avatar
Re: Painted my M/C with Eastwood Brake Gray
It looks good, let us know how it holds up, I want to use it if it lasts.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 02-05-2012, 10:14 AM   #3
corvettejim1968
corvettejim1968's Avatar
for exhaust i have done ceramic coat. its the same process as powder coat and will hold up for years. it comes in black, 3 shades of cast... light, med, and dark and shinny silver. call your local powder coat shops and see if they do ceramic.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 02-05-2012, 11:54 AM   #4
chevyrestoguy
chevyrestoguy's Avatar
That master cylinder looks really nice. I like the cast iron or "cast blast" finishes. It gives you the look of bare cast iron with the protection of paint.
What did you paint the cap with? It looks new.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 02-05-2012, 12:06 PM   #5
sigshooter
sigshooter's Avatar
The master cylinder was new but flash rusted quickly due to the humidity here in good ol' Oklahoma. The cap came gold anodized or plated when new so it has held up ok. The wire retaining clip I painted with a dull metallic alum. silver Krylon has, it resembles silver cad plating.
1966 Short stepside
1964 long bed
Old 02-05-2012, 12:12 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
I painted my new M/C with "cast grey" from VHT.
It was rusted thru in less than a year.
I hope yours holds up better.
I buy aftermarket aluminum master cylinders now.
(dual reservoir for 67-72 trucks)
Keith
Convert to disc brakes.
Old 02-05-2012, 12:14 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
I'm looking forward to seeing how well it holds up. Not many things tolerate brake fluid. If it holds up as well as advertised it would be a real blessing. It seems almost inevitable that a small drip will end up on the painted surface when installing a master cylinder, or when removing the lid to check the fluid level.
Old 02-05-2012, 07:26 PM   #8
ljackson
ljackson's Avatar
x2
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 02-05-2012, 08:09 PM   #9
sigshooter
sigshooter's Avatar
I read the reviews and talked to a few people that have used it and they say it works great! I will let everyone know how it holds up. Time will be the test, so stay tuned.
I am pleased with it so far, it covered great and looks fantastic so far. It took very little paint so I have tons left to paint other things.
1966 Short stepside
1964 long bed
Old 02-05-2012, 11:10 PM   #10
chevyrestoguy
Maybe try a satin clear to preserve the new cast iron paint??
Brake fluid is pretty evil on paint, that's for sure.
My build threads:
Old 02-06-2012, 07:01 AM   #11
jj1965
jj1965's Avatar
Silicone brake fluid is easier on the paint, not as good for a performance brake system but doesn't eat paint. It is expensive, but can be bought locally @ Autozone.
jj1965 is offline   Reply With Quote
Old 02-06-2012, 07:10 AM   #12
ljackson
ljackson's Avatar
Is Silicone brake fluid ok in older brake systems?
Old 02-06-2012, 07:26 AM   #13
darkhorse970
Can you tell us a good source for the aluminum m/c only, without the booster?
Keith
350/700R4
4/6 drop
1980 Silverado
Original paint
49k Original miles
4/6 drop
Old 06-03-2012, 05:13 PM   #14
sigshooter
sigshooter's Avatar
Ok it has been on the truck for awhile now and I have accidently spilled brake fluid all over it bleeding the brakes and it still looks good.
I highly recomend it and I am going to do other M/C's I have with it
1966 Short stepside
1964 long bed
Old 06-03-2012, 05:35 PM   #15
jocko
jocko's Avatar
thanks for the follow-up, looks good!
Old 01-19-2014, 09:37 PM   #16
sigshooter
sigshooter's Avatar
Re: Painted my M/C with Eastwood Brake Gray *update*
Update for those that wanted to know how it held up
A year and a half later and it still looks great! I have spilled fluid on it, washed it at the car wash, removed the master cylinder from the booster...
I would recommend this to anyone!
I just painted my blasted hood hinges with this since they were bare metal from the factory and they look nice. This paint is very thin and doesn't give it a painted appearance looks like bare metal.
1966 Short stepside
1964 long bed
Old 01-19-2014, 09:48 PM   #17
sigshooter
sigshooter's Avatar
Here is a pic a year and a half later
1966 Short stepside
1964 long bed
Old 01-19-2014, 11:08 PM   #18
chevyrestoguy
Wow! I'm sold!
Very impressed with their product, for sure.
My build threads:
Old 01-19-2014, 11:10 PM   #19
TJ's Chevy
TJ's Chevy's Avatar
I'm gonna have to look into some of that paint. My m/c is brand new an all rusty. Thinking of pulling it off and sanding it and putting some paint on it.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
