Old 02-05-2012, 02:00 AM   #1
drivea55
drivea55's Avatar
trans no leak , then leak
Hello again everyone,
Been running my th350 here and there and no leaks.
Decided to install the new speedo cable, came back the next day to a big puddle
Just wondering if anybody had this happen just by sticking the cable in there?
Is there a spec depth that the inner cable has to go and if its too deep it leaks?
Do enlighten this noob.
Brian
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 02-05-2012, 03:23 AM   #2
drivea55
drivea55's Avatar
Re: trans no leak , then leak
Sorry
I posted this when the forum glitched. So there somehow is a double post.
Admin should delete the clone asap.
current project;
Old 02-05-2012, 03:04 PM   #3
parkwood
parkwood's Avatar
well it's like the one on my '61 wagon that leaked it was the o ring in the housing that the speed cable screws on too... the gear that drives the cable fits in an o ring and the cable goes into the gear... for some reason the o ring was not pushed in far enough and wasn't sealing around the gear.. you may have to take the housing out of the trans to make sure it's sealed around the gear... just a hint: let the trans set for a while before you do this and it should not lose to much fluid... hope this helps.
parkwood is offline   Reply With Quote
Old 02-05-2012, 04:03 PM   #4
drivea55
drivea55's Avatar
Thanks for yoyur reply!
There is a lot on this doing a google search. It has to be the inner seal. What thru me off was without the cable on there it did not leak.
Maybe when i inserted the new cable it popped the inner seal.
I guess its better to happen now then on the road after the truck is finished.
current project;
Old 02-05-2012, 06:33 PM   #5
parkwood
parkwood's Avatar
Yes i wiped up my share of trans oil before i took it out and found the seal wasn't sealing around the gear...
