Old 02-05-2012, 02:48 AM   #1
ClassicGuy
Cool Will a s10 rear end fit my 70 C10 shortbed?
I want to change the six lug rear end to a five lug rear end and I was told that one from an S10 would work, is that true? If not, any suggestions on what would work.
Thank you.
ClassicGuy is offline   Reply With Quote
Old 02-05-2012, 02:53 AM   #2
shawno72
C/10 junkie
shawno72's Avatar
Re: Will a s10 rear end fit my 70 C10 shortbed?
Curios as well.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 02-05-2012, 02:59 AM   #3
69C-owner
id say much too narrow
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 02-05-2012, 05:49 AM   #4
Pop's C-10
Pop's C-10's Avatar
B-body or a 73-98 full size..i'm sure vans would also..with spring pad swaps
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 02-05-2012, 06:20 AM   #5
YBNORML
YBNORML's Avatar
I don't know whether or not it will fit, but I can go out in the shop tomorrow and measure from backing plate to backing plate for you.
The bolt pattern is different from the c-10 though. The s-10 is a 5 on 4-3/4 where as the c-10 5 on 5.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 02-05-2012, 07:55 AM   #6
hugger6933
48 inches to backing plates if I remember. Now there are some 4x4 S10 that the rear is 4 inches wider than the 2wd and the ZR2 is even wider than the regular 4wd but they are kinda hard to find and are crazy expensive when you do. the bolt pattern is not 5on 5 it is 5 on 4 3/4 like a small to mid size car. The astrovan may be worth looking into, it is wideer and had 5on 5 bolt patterns
hugger6933 is offline   Reply With Quote
Old 02-05-2012, 11:56 AM   #7
With all the full size 1/2t trucks in the world,why not use one of those? S10s are narrower AND you need to do something about modifying the mounts. A '73 or newer you just have to modify the mounts..if you have a coil spring truck.
Old 02-05-2012, 05:13 PM   #8
ClassicGuy
Thanks for the replies guys, very helpful information.
Old 02-05-2012, 05:21 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
A '70 rear end is the same width as the '71-74 truck. Simply swap axles and brake drums from the later units. It's us who have a '60-69 that have more trouble finding a proper-width axle and have to swap rear ends or get aftermarket 5-lug axles. You're lucky.
Member Nr. 2770
Old 02-05-2012, 05:45 PM   #10
68short
68short's Avatar
I have a 2wd s10 rear waiting to be swapped into my vega, and its 54.5 . I think the 4wd units are 59"
(outer dimensions)
68short is offline   Reply With Quote
Old 02-06-2012, 12:48 PM   #11
ClassicGuy
I will try and get the axles from the wrecking yard today. Any hints on how to to the axles out? I have never done that.
Old 02-06-2012, 09:44 PM   #12
68short
68short's Avatar
The axles are pretty easy to remove, first take the drums off, then take the rear diff cover off, remove the 5/16" bolt holding the pin-( use a 1/4" drive ratchet, as they sometimes snap using anything larger, your screwed if the bolt holding the pin snaps. If it snaps you'll need an easy out to remove the pin) return to one of the axles and push it in a little and the c-clip will sometimes fall out. If not then try to grab them manually
Old 02-06-2012, 11:15 PM   #13
ClassicGuy
Cool thank you
Old 02-08-2012, 01:52 AM   #14
ClassicGuy
Do I need to change the gears on the diff or will the axles just slip into my 70 diff?
