Old 02-05-2012, 03:25 PM   #1
Stringer
90 Burb....fan blows only @ floor
Need more hand-holding, please. Been reading old posts but it's not sinking in, I guess.
Got air and heat but it only blows out the floor vent. It'd be nice to have defrost, etc.! I know the plastic door pull is broken but the cable doesn't have any movement anyway. I mean - moving the selector switch does nothing. I don't hear any actuators actuatin' - no clicking under the dash. Is this most likely a vac problem? Any other thoughts?
finally - new CD - 2-7-12
Stringer is offline   Reply With Quote
Old 02-05-2012, 03:32 PM   #2
kwin
kwin's Avatar
Re: 90 Burb....fan blows only @ floor
I have had this problem with some of the Fords in the fleet that I manage, it seems to come down to actuator motors ( vacuum motors in your case ) or jammed flaps. For the new fords it's a $2000.00+ repair!
I know thats not much to work with but i think you are on the right track.
kwin is offline   Reply With Quote
Old 02-05-2012, 07:36 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
The switch does fail. If you don't hear it moving air when you move the switch then make sure it is getting vacuum.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-08-2012, 06:39 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
check here too,from my 88
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-08-2012, 06:59 PM   #5
Stringer
Thanks. I bet defrost in Ottawa is more essential than in North Texas but it's still a PITA not having it. Anybody know of a way to test the actuators-the round thing the vac line is hooked to?
Old 02-08-2012, 07:49 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
haha can't start the day without it lol
blow and suck......cheap n ez lol
i've used the washer/wiper hose to check them
John
Old 02-13-2012, 07:15 PM   #7
Jonboy
Slots go on anything!
If that clip doesn't fix it, the vacuum switch on the back of the A/C control head may be the culprit. They are prone to going bad, too.
1974 Jimmy- 5.3/4L80e/NP241
Old 02-13-2012, 08:18 PM   #8
Stringer
Thanks to everybody for the help. I think I've got it fixed as of yesterday. A: broken vacuum line under hood. B: broken clip on the blend door. I artfully crafted a Copenhagen lid to take care of that. Next project is getting some lights to work behind the gas gauge. Thanks again.
