Resident Photoshop Nerd
Found out something interesting..
So, we're doing a rebuild on what we thought was the factory 283 v8 for PJ. We decide to finally run the numbers while its out of the truck. Seems that it is actually a 1975 400 small-block that someone put a 283 intake on. (I'm assuming the PO decided to keep an aftermarket intake and just threw on the 283 intake just to be able to drive it.
We don't have it all torn down yet, so we don't even know if its salvageable yet. This is what we can't figure out. What was built in the Fremont plant in 1975? Terry wants to know as much as possible about it. Posted via Mobile Device
PJ - 1966 C10 Panel -- Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Found out something interesting..
The numbers and suffix code on the front passenger side of the deck surface of the block will tell you as much as is available for that engine.
Damn.. we've tried that, and there is zero info on the vehicle it went into in 1975. The CSB is pretty much skipped over on the sites we HAVE found with information. Which is why I had hoped one of you guys would know :\
60-66 Nut
If the block was cast in '75, depending on the month, it could have been installed in a '76 model car. Here is what I have found
http://www.nastyz28.com/gm-chevy-cod...s-suffix-3.php
Is CSB your suffix code? If it is then there are 4 possibilities,
CSB 73 400 Impala CSB 75 400 Chevelle CSB 76 400 Marine CSB 76 400 Chevelle
CHEVY/GMC VIN DECODERS |
![]() Join Date: Mar 2005
Look on the back of the block at the part number. It should end in -509 or -817. The later 400s were almost always the -817 blocks. It's a 2-bolt main, but that's actually a good thing. Those engines got a bad rap years ago for no reason at all, usually from people that never owned one. A 400 is a great engine for a street machine. It's give you the torque of a small big-block with the size of a small block. I'm a huge fan of 400s.
I say build it! You'll like it, trust me.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#7 | |
Resistance is Futile
FYI, 400's were put in many trucks, too. I see Blazers with them all the time. I got my original 400sb from a Caprice.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
So far, this thing is not too horrible, but we're noobs, so we don't know what to look for as far as 'damaged' stuff goes.. We only have the driver-side head off now; tomorrow we're probably gonna pull off the other.
We know it wasn't the original engine due to the fact it's a '75, and our truck is a '66, and according to the VIN was supposed to have a 283.. (the intake was all that was left of the 283, siliconed to death on top of the 400) but obviously, the 75 is a lil bigger at 400. LOL We were curious to see, because we have a transmission we cant figure out (without pulling it out to check the numbers). We were kinda hoping the 400 and the trans were from the same 'donor' '75 vehicle; it's from a Car, that we know by the position of the shifter, and it's pattern; but otherwise, we'll have to drop it to figure it out "for sure".
My 76 k10 came with a 400.
Doug 66 4x4 GMC Suburban 76 4x4 Chevy Shortbed |
I like the 400, But others in my circle of trucks give them a bad rap. I will follow your progress to see what is up. Good luck.
From your neighbor down south. I have a 66 as well.
Why can't I find it until the last place looked? 65 Longbed 283 three on the tree. 66 Longbed 292 three on the tree.Pennys A/C Trucks made in USA Buy a much as you can, Made in the USA |
I liked the 400. Good power. I did tow alot and the torque was good. When i lost the rod in it there was serious damage done to the block or id have rebuilt that one.
#13 |
Is that an old Ford 8n tractor all restored behind the camo burb?
#14 | |
#15 |
My bad. It a panel. I like those old tractors.
#16 |
You could always build a 377 out of the 400 block.
#17 |
"Where were you in '62?"
![]() Join Date: Jul 2004
![]() The (BEST) and (WORST) Small Block Chevys Engines Of All Time http://67-72chevytrucks.com/vboard/s...d.php?t=386581 Small Block Chevy Engine Block Identification http://67-72chevytrucks.com/vboard/s...d.php?t=353538 Growing to it's largest factory displacement of 400 cubic inches in 1970, these block required siamesed cylinders to gain the internal space for the displacement. Extra bolt holes were also drilled into the surface of each deck to promote cooling. It is also noted that for the use of a small block 400, you also need the small block 400 heads. Most of the crankshafts and connecting rods from the small block 400's ended up with a better life as part of a 383 build-up. The only 400 cubic inch size of this family, 400 cu in small-block, was introduced in 1970 and produced for 10 years. It was loosely based on the 'medium' journal 350 and had a 4.125-inch bore and a 3.75-inch stroke. The 400 differed from other small blocks in that the cylinders were cast siamesed, used a 2.65” 'large' main bearing journal, and oftentimes had one more core/freeze plug on both the left and right sides of the block. Initial output was 265 hp and was only available equipped with a 2-barrel carburetor. In 1974 a 4-barrel version of the 400 was introduced, while the 2-barrel version stopped production in 1975. 1976 was the last year that the 400 was used in full and mid-sized Chevrolet Passenger car, available in both A-Body and B-Body lines. While popular with circle-track racers and drag racers, the engine could be prone to cooling problems if cylinder heads without added steam holes were used. I'm not a fan of them myself. It's popular in drag racing around my neck of the woods. Got one for sale though! ![]() 1970 Chevy 400 cu in SB, Casting 3951511 Canadian Block http://67-72chevytrucks.com/vboard/s...d.php?t=408630 Casting CID Year Model Aplication Comments 330817 400 73-76 Passenger 2 bolt main,3 freeze plugs/side 330817 400 75-80 Truck 2 bolt main,3 freeze plugs/side 3951509 400 73-76 Passenger 2 bolt main, 2 freeze plugs/side 3951509 400 75-80 Truck 2 bolt main, 2 freeze plugs/side 3951511 400 70-73 Pass,Chevelle,Monte 4 bolt main, 3 freeze plugs/side 3951511 400 75-80 Truck 4 bolt main, 3 freeze plugs/side ![]()
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#18 |
330817 400 75-80 Truck 2 bolt main,3 freeze plugs/side ^ our engine has 2 plugs and has this casting number.. o_O franken motor.. dunnn. dunnn... dunnnnnnnnnn
#19 |
Also -- we're kinda stuck, terry doesn't want to order online, anybody have an alternative way of turning the crankshaft without the balancer on?
#20 |
I was told they got a bad rep because people would mess with them and put different heads on them and forget to drill the steam holes. They would over heat and so on so people call them junk. I had one and it ran great, never had a problem. Its just like the quadrajet. Everyone hates them but they are a great carb.
Bud |
#21 |
hey suzq044,
You're already gettin plenty of help on the engine side of things. Let's see if I can help on the trans side of things. Crawl under it w/ a pen and paper, or arm or hand. Draw the basic shape of the trans pan. TH350 will look like a square with one corner cut off. The TH400 will look kinda like Texas. Hope this helps...
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
#22 | |
![]() Posted via Mobile Device
#23 |
Thanks for the Pic, Pro Street. I agree with the 400 and Q-jet "bad rap" I've never had a problem with the 1 400 I had. I had problems with a stock Q-jet, but once I got it tuned up and in, it was great!
#24 |
60-66 Nut
If you are talking about turning the crank with it still in the engine, a correctly sized crescent wrench will work just fine as long as the key is still in the crank.
#25 | |
