Old 02-05-2012, 07:48 PM   #1
shortbed70
shortbed70's Avatar
Might get a 6.0ls
My question is I plan on carburating it because no intake or computer so what all will I need to put this in front of my 700r4 in my 65?
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 02-05-2012, 08:31 PM   #2
85burb
85burb's Avatar
Re: Might get a 6.0ls
This is the kit i used.
http://www.advanceadapters.com/products/pn-712500a/
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-05-2012, 10:12 PM   #3
Pop's C-10
Pop's C-10's Avatar
That is not a bad price...:-?
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 02-05-2012, 10:22 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Make sure that 700 will handle the torque. With a decent cam you can put out 450+ tq and the 700 won't handle that IMO.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-05-2012, 10:42 PM   #5
85burb
85burb's Avatar
I know my 700 held up for a while and is still alive. A stock one you can prob bet it will fail soon if you drive like me. A built one should hold up. I have a stage 2 rated at 450 tq and i am sure i am close to it and mine is staring to shift soft. Get one built as strong as you can find. These motors are stout.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-05-2012, 11:21 PM   #6
shortbed70
shortbed70's Avatar
If it breaks it will give me a reason to put a 400 back in it.
Troy
Big Red Dog build
Old 02-06-2012, 09:52 AM   #7
Shon
First you need to determine which flexplate you currently have. if it does not have a spacer on the crank then you can just use
If you have the spacer on the flextplate then you do not need anything other than possibly redriling or elongating some of the holes.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 02-06-2012, 08:10 PM   #8
Ranger6202
I thought the 6.0's bolt up to all th350, 400 and 700r4. Its the 5.3's that need the spacer. Or is the 700r4 like the 4l60 and thats why you need to change the 6.0 set up?
Ranger6202 is offline   Reply With Quote
Old 02-06-2012, 11:19 PM   #9
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
The 6.0 will already have the spacer if it came in front of a 4l80e. If the engine had a 60e behind it then it won't have the spacer.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
