Old 02-05-2012, 10:03 PM   #1
50mercfan
50mercfan's Avatar
need help with engine mounts/stands
hello fellas, ive got a 72, 350/350 turbo. the engine came in the truck in this position. problem is i can't get a throttle cable that is short enough. i bought the long one not knowing there was any differance. i bought the short one today at the nashville swap. it's still too long. one vender told me that me engine was in the 4wd position another told me that the stands are in the 6cyl position. can someone shed some light? i'm going to move it forward i guess. do i need different engine stands? there are no holes on the cross member for the forward position. there are some higher on the frame though.
50mercfan is offline   Reply With Quote
Old 02-06-2012, 12:18 AM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: need help with engine mounts/stands
The engine mount stands should be moved forward to the next hole, thats the way mine is with a 283 V8 originally. Im not sure about 4wd or 6cl mounting maybe check the glove box sticker? what engine did your truck originally have? I may have some pics showing where the stock V8 mounts go if you need.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 02-06-2012, 12:25 AM   #3
thelonerife
thelonerife's Avatar
They look like 6 cyl stands. I will take a pic of mine.
thelonerife is offline   Reply With Quote
Old 02-06-2012, 12:31 AM   #4
thelonerife
heres mine
Old 02-06-2012, 12:50 AM   #5
67c10rustbuket
heres mine, just as thelonerife mine are in the front holes. I dont know about these trucks but I do know on many model GM used different stands for V8 or I6 so you might need to get some V8 mount stands. Note that the mount stand on the pass side is right next to that bulge in the frame unlike yours.
Dan <---(my name)
Old 02-06-2012, 10:17 AM   #6
50mercfan
50mercfan's Avatar
thanks guys, that will be some help. my spid said 350/350 turbo. i don't know why someone would move it. when i got it somebody had crimped electrical eyelets onto the throttle and kickdown cables which i thought was wierd.
Old 02-06-2012, 02:02 PM   #7
FirstOwner69
FirstOwner69's Avatar
If they are small block stands (I don't know what the 6 cylinder stands look like), they are in the wrong position as noted above. It also appears they may be mounted on the wrong sides. In other words, the right stand on the left side and left stand on the right side.
FirstOwner69 is offline   Reply With Quote
Old 02-06-2012, 04:12 PM   #8
50mercfan
50mercfan's Avatar
yea, firstowner, thought that too but wasnt sure
Old 02-06-2012, 04:49 PM   #9
VWBeamer
Does your drive shaft fit? If you move the motor two inches forward, then it will be too short.
VWBeamer is offline   Reply With Quote
Old 02-06-2012, 08:50 PM   #10
too much stuff
Roadtrip!
too much stuff's Avatar
I can't quite tell on your stands which ones they are, but your engine is in the 6 cyl location. (4x4 location also) I think if you get a cable for a 4x4 it should work.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-06-2012, 10:00 PM   #11
crazy longhorn
Fabricate till you "puke"
2nd that on the 4x4 cable....if you swap to V8 sb stands , you will move the eng 3 1/2" forward, & need driveline mods to boot crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-17-2013, 03:45 PM   #12
lawest
I have a 69 K10 that originally came with a 6 cyl. in it. The PO swapped in a 283 V8 but it looks to me like the engine sits way far back. I am getting ready to swap to a 350/350 set up and was wondering if anyone knew of a site where all the optional engine stands and locations were described so I could figure out what I need?
69 K10 SWB Project Dream '69
2011 K2500 Silverado
Beat to fit, Paint to match
Dream '69 Build Thread
lawest is offline   Reply With Quote
