02-05-2012, 10:14 PM | #1 |
rockers to cab corners- what to do?
Ok, I have my rockers all installed and they look ok with a decent gap to the cab corner. The question is finishing. Do you a. finish as is? b. seam seal the gap? or c.weld it up and don't worry about it? Getting ready to go forward and was looking for opinions/ experience. Thanks, Chip
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-05-2012, 11:49 PM | #2 |
Re: rockers to cab corners- what to do?
I just got my driver side rocker and corner installed last weekend. I went ahead and just welded the gap. This is my first panel replacement project, but that is what my mentor recommended to me.
02-06-2012, 12:39 AM | #3 |
I also welded the gap, as the cab corners i got didn't exactly have much to work with at the gap.
02-06-2012, 07:14 AM | #4 |
I would do it the way the factory did and leave it be. Think ahead to when you may need to replace again.
02-06-2012, 07:29 AM | #5 |
Tim, that was the idea when it was first done, but I was reconsidering a bit before shooting color. Please, keep it comin'!
02-06-2012, 09:39 AM | #6 |
I would leave it open for any drainage or body flex that may need to occur.keep in mind also that in the case of a collision, damage can spread from one panel to the next that much easier as well as make either harder to replace. Having said that, if it is a show piece and it would add to the effect go for it!
Posted via Mobile Device |
02-06-2012, 12:19 PM | #7 |
I have wondered about this for years. So the factory didn't do anything to seal it? It was just left with the gap? Afer 30 years it is hard to tell what they looked like originally, and I also would like to know. Good Q!
"You can take the man out of PA, but you can't take PA out of the man" |
02-07-2012, 02:07 PM | #8 |
Does anyone have pics of a DEAD FACTORY truck for comparo? Ours was already done (badly) when we got it.
02-07-2012, 02:52 PM | #9 |
Pretty sure they were seam sealed from the factory.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-07-2012, 02:55 PM | #10 | |
02-07-2012, 08:10 PM | #11 |
I always seam seal it then take my finger and remove the excess leaving a nice filled grove. Let it cure for 24 hrs or so before priming or it could cause problems.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
