Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-05-2012, 10:36 PM   #1
geoff.clark
SheetMetalNoob
geoff.clark's Avatar
Compressor Help
I am trying to identify why the pressure release valve keeps dumping around 140 psi. I bought a new eaton compressor last year. I never had an opportunity to run it until this past month due to lack of money to finish wiring. So I ran into my first issue where the pressure switch had a broken on/off switch. I replaced this and now running into my current issue.
The prv dumps around 140, this is a 150 psi prv. I have spoken with eaton and they are telling me the check valve needs to be cleaned. I dont have a major issue with this other than it is brand new and why would it be clogged / dirty. I understood the check valve as a one way valve and would only dump back to the unloader valve when the pressure switch stops the motor.
Can anyone help explain why / how the check valve would cause the prv to dump before the max psi of the valve?
Thanks so much
Geoff Clark
Classic Truck NoOb
83 Chevy Custom Deluxe I6 250 lwb (aka) Trash Runner
geoff.clark is offline   Reply With Quote
