Old 02-05-2012, 10:56 PM   #1
resto_rookie
resto_rookie's Avatar
Steering Ratio?
Ready to order new power steering box but not really sure what ratio I need.
69 SWB Fleet/72 running gear
Currently under frame-off
67 SWB Stepper smallwindow
resto_rookie is offline   Reply With Quote
Old 02-05-2012, 11:38 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Steering Ratio?
There's a few ratios available but I found that the quick ratio 2.5 turns of the steering wheel lock to lock made my 68 GMC a little squirrely on the highway. I swapped to standard ratio -app 3.5-3.75 turns lock to lock -and it handles better on the highway.
However, if you do a lot of in town driving then you may want the quicker ratios.
68gmsee is offline   Reply With Quote
Old 02-06-2012, 08:20 AM   #3
resto_rookie
Re: Steering Ratio?
Thanks but what I don't understand is the 16:1, 14:1, or 12:1. Which one of those is the factory style or which one is the quick?
Old 02-06-2012, 10:21 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: Steering Ratio?
They're all factory ratios if installed in a stock gear box. The higher ratios (ex. 17:1) means you have to turn the wheel more than the lower (12:1) turn the wheels. Here's a short writeup from this site.
The steering ratio is a number of degrees that the steering wheel must be turned to pivot the front wheels 1 degree. The higher the steering ratio (30:1 for example). the easier it is to steer the vehicle, all other things being equal. However, the higher steering ratio, the more the steering wheel has to be turned to achieve steering. With a 30:1 steering ratio, the steering wheel must turn 30 degrees to pivot the front wheels 1 degree.
Actual steering ratio varies greatly, depending on the type of vehicle and type of operation. High steering ratios are often catted stow steering because the steering wheel has to be turned many degrees to produce a small steering effect. Low steering ratios, called fast or quick steering require much less steering wheel movement to produce the desired steering effect.
Forgot to add> I would stick with the lower (quick) ratios if you will drive mostly in town. Get the middle range ratios if mostly highway.
Old 02-06-2012, 10:42 AM   #5
resto_rookie
Re: Steering Ratio?
Wow thanks! Makes sense now
Old 02-06-2012, 02:51 PM   #6
chachi127
Re: Steering Ratio?
I like this one variable ratio, best of both worlds. It is a bolt on but hoses and pump might have to be changed, depends on what engine your running. The guys at ARG are happy to answer emails. http://www.summitracing.com/parts/AG...UP&prefilter=1
1972 GMC 'Project Red'
Long Road Ahead
chachi127 is offline   Reply With Quote
