You folks that have air bags/ air suspension who did you use? Little at
I'm curious on you guys that have air bags/ air suspension who did you use? Little at a time or all at once?
two way or 4 way? Who is quality not just the most advertized? Are the ride height sensors worth it? Thanks, Rob |
C/10 junkie
Re: You folks that have air bags/ air suspension who did you use? Little at
X2
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
![]() Join Date: Apr 2004
I pieced my kit together from other peoples abandoned projects and installed it myself. Check the classifieds for deals.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
You are better off with a 4 way setup for 2 main reasons. 1) It will handle better with a 4 way, with a 2 way setup the air tranfers from one side to the other when you are in a corner allowing for more body roll. 2) It will be faster inflating and deflating.
As far as the ride height sensors go, alot of it is personal preference. Myself, I wouldn't have another truck without it (or I should say my wife wouldn't let me). I have a suburban on air for a daily driver and with the leveling system, I never have to worry about it even if I got 8 people in it I know it will be sitting right.
www.ridetech.com |
C/10 junkie
Thats good info Randy.
THanks very much.
![]() Join Date: Mar 2007
I have an older air ride 4 way system. No sensors as it was purchased before that technology existed. I like it but would like to upgrade to an Accuair controller. I have found that the ride hight can very even when you have the same amount of air in the system. I pretty much eyeball my front air A-arms to make sure that I have it back at the correct ride hight.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#8 | |
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Mine was done at once. I agree with having the four way. I do not have those problems of side-to-side. I was on the highway yesterday sitting a few inches off of the ground, in a curve, and it was hugging the road. Awesome feeling! I have a four-link rear, panhard, nice c-notch, 2 ViAir compressors, 5 gallon tank, have front, back and pancake setup. You can get away with normal switches. I am sure the AccuAir will be cool if you are on the highway and want to lower while moving...I know my truck really well, so I know where it is up, down or otherwise.
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
My '69 was pieced together with 8 valves and a 7 switch box. Worked awesome. Not sure if I will do ride sensors or not on the '66. I think they are cool and would love to tie it into the iControl system when it comes out for Android.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
I have the ride tech kit with the E3 leveling sensors and it has worked great so far.
I based my descision on reputation and how long the company has been in business.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
needs more $$$
I did the same as Hotrodhomi which made it as cheap as I could get it. I really would love to have an auto leveling system though...It's just not in the budget. If I had to do it all over again, I'd run Accuair's air management instead of 8 seperate valves. The price isn't much more than 8 valves and makes installation much easier...that and upgrading to the e-level system would be simple.
1970 2wd Blazer |
#13 |
I just talked with Bo @ Air Ride ( I wasn't sure if I could ask for you Rodney) and I think I'm going their way with my stock A arms with their bags & shocks. Dual compressors and either 1 five gal tank or 2 three gal tanks. the digital controller and ride height sensors. For about $2700.00 but after research it doesn't seem to get cheaper and they have been around well and have some well engineered packages. Do it once and be done with it.
#14 | |
#15 |
If you have the time you can build your own 4 way auto leveler. Thats what I have done, and you can have a touch screen or wireless controls to control it, and any parameters that you want. On top of it your looking at a lot less dough! my buddy and i have it in one vehicle that is testing it in winter weather salt and grime and farming conditions and working out all the bugs now, and will be installing it in my 67 as soon as I get more time to get the dang thing done.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
#16 | |
#17 | |
Thats the right choice....
#18 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#19 |
@ SevenOne and Gringoloco Here is a pic of the screen/ controller the microprocessor chip sits directly underneath as the screen plugs in. It is a 3" screen (stock photo on the screen). It is about 3/4" thick mounted. The other is of the valve bodies with the sensors mounted on them that monitor the individual bag pressure. run your hard or soft lines directly to them. The valves can be controlled via the processor, wireless control through the processor, or manually at the valve themselves. The valves are industrial use valves and are waterproof, and extremely shock and vibration resistant. they are aluminum bodied, with an aluminum valve block that they mount into. I dont have a photo of the ride height sensors taken but, they are a stainless ball bearing angle actuator that converts angular/height into a voltage signal to sense height.
#20 | |
#21 |
longbed, you beat me, slow typing, thanks for the info
#22 |
hey longbed, who makes the controller-processor? do you have to program it?
#23 |
I have been in Chicago since wednesday at the auto show and at CSM for the american physical therapy association national meeting.
So, the controller and processor are made in house. They are all programed in house and then once you plug in the harness to valve bodies after everything is installed you press a button on the touch screen let all the air out (or as low as you maximally want it to sit), press a button to set it, press another to press the baggs all the way up stop it where you want it to sit maximally press another button set it and your done. ![]()
#24 |
The valves and controller will work with any air bag set up, heres the part I like. All the parts that we use to make everything are made in the USA, Germany, and Italy. NO cheap Chinese crap!
#25 |
WOW Very cool.U plan a write up on that Adam?
