02-06-2012, 09:29 AM | #1 |
Help identify master cylinder
I was wondering if some one can identify this master cylinder as it is leaking and has to be replaced. I know that it isn't same style that originally came with the truck.
1970 442 convertible 1970 Cutlass SX 1962 Chevy Stepside 2011 GMC 3500HD Crewcab SLT DRW |
02-06-2012, 12:46 PM | #2 |
Re: Help identify master cylinder
Hi m455sx,
Looks to me like a 64-66 master cylinder. |
02-07-2012, 01:01 AM | #3 |
60-66 Nut
I agree....it is a '64-'66 pickup master cylinder. I would consider switching to a dual reservior master cylinder and splitting the lines. Does your truck have front disc brakes or drums?
Nice truck and engine BTW
02-07-2012, 11:08 AM | #4 |
It has drums all the way around. I want the dual master cylinder and want the lines to look more stock than it does now. keep in mind if you guys point me in the right direction with the right tools i can make the repairs happen.
02-07-2012, 11:09 AM | #5 |
Also can people supply pictures of the reservoir like mine as well as a dual set up.
02-07-2012, 12:59 PM | #6 |
heres my stock style replacement (same as yours without the booster)i got at local auto parts store,planning on doing the dual master in the near future......
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
02-08-2012, 01:42 AM | #7 |
60-66 Nut
Here is a good writeup that ChiefRocka did on converting to a dual reservior master cylinder. This and many other informative threads can be found in the '60-'66 FAQ index at the top of the page.
http://67-72chevytrucks.com/vboard/s...d.php?t=332148 You can also use a master cylinder for a '67-'70 truck.
02-08-2012, 07:53 AM | #8 |
thnx, that was cool!
