02-06-2012, 10:23 AM | #1 |
New engine or new friend?
While checking out my newly acquired 53 3100, I noticed that I was unable to turn the engine over by hand. So I removed all the spark plugs and squirted liberal amounts of Marvel Mystery Oil into the cylinders. Using a pry bar on the flywheel loosened things up considerably. I then hooked up the starter and let the engine fly without the spark plugs. My friend asked me if all the Marvel Mystery Oil came spitting out the the spark plug holes when I spun it over. I had to honestly answer no, it didnt. He took that as a bad sign and reasoned that all the rings must be stuck and consequently the motor will have no compression. He advised me to stop right there and look for a replacement motor. What do you guys think? Replacement motor or replacement friend? Im not inclined to giving up on it just yet. Id like to get it started and go from there. Of course it goes without saying that I also dont like throwing good money after bad. What to do?
One interesting feature on this motor is a finned aluminum Offenhauser valve cover! Makes me really wonder what else might have been done to this engine- probably nothing but it doesnt hurt to dream. Ive already ordered a stock valve cover since an item like that will be just too pretty to keep on this truck- not in keeping with the overall theme. I imagine that once polished up it will be a real crowd pleaser which is not my style. I just want a nice drive around pickup, the stocker the better. |
02-06-2012, 12:36 PM | #2 |
Re: New engine or new friend?
Throw some plugs in it and fire her up...what have you got to loose??
Life is too short to drive a boring vehicle. |
02-06-2012, 01:02 PM | #3 |
I would at least try to get it running. no sense in trashing the engine if you never really tried to run it. You could run a compression test to see whats really going on in the cylinders.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
02-06-2012, 02:47 PM | #4 |
Run a compression test and check for electrical. If its been sitting for a while replace the gas (drain tank) and put in a good filter between the tank and fuel pump to catch the crud. Check oil and see if it fires up if compression is enough to start. It might come back to life. My 64 had been sitting for a while, smoked like crazy, made rattly noises for the first 100 miles than settled in and ran for 60K more miles. Since it broke loose that easily could just be a little condensation over time thru the intake and exhaust via open valves. I grew up with my old man and grandfather Orrie getting those old things running.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
02-06-2012, 04:49 PM | #5 |
Thats what I hoped. If I run it a little while maybe the rings will become unstuck. Probably it will smoke for a little while. I think I need new friends. Running a compression test on it now seems like a waste of time if Im going to run it for awhile anyway. After a 100 or so miles, if its still running like crap, Ill do a compression test and even if it fails then I may give it some more time.
This truck need so many things that putting off engine work will allow me to focus on other things- like brakes. |
02-06-2012, 05:15 PM | #6 |
I think your friends were trying to save you a large tow bill.
Good Luck
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
02-06-2012, 05:30 PM | #7 |
Really, compression testers and such are for the rich and famous....who needs them. the proof is the pudding. if it starts, then has enough compression to run...and who needs more?
High compression = High test gas= High gas cost! What if it burns a little oil, I'm sure all your rich friends change their oil in there trucks. More than likely they would be happy for you to have their old oil. Your truck would put it to good use, and it prevents you friends from improperly disposing of their used oil...keeping this old motor is just plump green. It's the right thing to do really. When people tell me that my truck smokes, I simply remind them that it's old enough to do so. Sometimes they mention air pollution, but I say particulate emissions help block the suns rays and reduces the green house effect. Again, your curbing Global warming...think about it. If you change the motor for a rebuilt one you're going to damage the earth! Clearly, you are correct in your thinking, I would encourage you to continue with your current plan of attack. |
02-06-2012, 07:06 PM | #8 |
Some of the Marvel Mystery oil is going to soak down through the rings. That is what it is intended to do when you squirt it in the cylinders.
If it spins over good with the starter I'd throw in a fresh set of plugs and the fresh gas and filter between the tank and fuel pump and give it a go. If the gas filler smells like varnish I'd probably put a length of hose on the intake side of the fuel pump and run it to a small gas can or container of gas. It doesn't take a lot to get it going and running to see if it has oil pressure. If it runs decent and doesn't knock but burns a bit too much oil it isn't that hard to pull it down and put in a new set of cast rings and be ready for another few years of cruising. Back in the 60's the local mechanics could pull the head and pan, push out the pistons, clean things up and put the pistons back in with new rings and grind the valves and have one of these trucks running by quitting time. Some could do it by lunch. I'd still see if I could get it running and see if I could drive it at least up and down the driveway. Then if it just doesn't do the job you can decide what avenue to take with it. |
02-06-2012, 07:56 PM | #9 |
Thanx. That is exactly what I will do.
02-06-2012, 09:40 PM | #10 |
Hollister Road Co.
Good compression is for those that can down shift when going up hill.
02-06-2012, 10:25 PM | #11 |
If you have good compression, you don't need to downshift when going up a hill.
Posted via Mobile Device |
02-07-2012, 07:31 AM | #12 |
Elev8r Man
I had a 50 suburban with a similar situation / friends. I simply ran it dry to remove the oil in cylinders, put in new spark plugs, cap, rotor, wires, points and fired her right up. It smoked a bit although it ran great. I put the money forward figuring that if I nedded to have it rebuilt these items wouldn't have too be bought later.
I would say try it out because you have nothing to lose and everything to gain, if it runs then you save the money, if it doesn't then you have it rebuilt and at least the knowledge that you tried. Posted via Mobile Device
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!! 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
02-07-2012, 09:05 AM | #13 |
So true. Words to live by. Thanks for the encouragement
02-07-2012, 02:36 PM | #14 |
Its amazing what will run. My first truck was a 47 ford with a well worn flathead. It would not start with the started, had to roll down a hill to build up compression, luckily all my friends and girl friend lived on hills. It used 1 quart of oil every 10 miles and had twin bed stacks. It looked like the Queen Mary steaming down the road. I worked part time in a gas station so I had access to lots of used oil. Once started it ran fine. I drove it for 6 months before I broke an axle. Paid $40 for it and sold it for $50 (this was 1968) to a dirt track guy that wanted the open driveline tranny for his race car.
02-07-2012, 03:31 PM | #15 |
IMO if you’re not too worried about salvaging the engine, new plugs, oil, fresh gas and fire it up. If it runs fine you can decide what you want to do from there.
If it grenades you never really lost much especially if your grand plan includes a V8 in the future Just my 1/50th of a $ |
02-07-2012, 05:13 PM | #16 |
I'm with the guys who say to start it up and see what happens. You might be surprised how good it runs after it warms up and gets oil circulating.
Orrie, My first truck was also a 47 Ford that I purchased in 1970 for $150. Mine had a 50 Merc flathead that ran pretty good. |
02-07-2012, 05:26 PM | #17 |
Bet you wish you still had it.
02-07-2012, 07:25 PM | #18 |
I was born in 1985. The only thing I could buy for $100 to drive when I was of age (2001) was something along the lines of a 1985 Plymouth Reliant!my friend paid $100 for his Dodge Omni. I envy you all for having such opportunities!! haha. I was lucky enough to fix up my dads old commuter mustang and drive it with its big 200CI I6 when I was 16, but man 90% of the cars of the 80's were dogs.
02-07-2012, 08:38 PM | #19 |
Back then 46-47 were the ugly cousins to the 39/40's and F-1's. I wish I had every car I owned and the ones by Dad wouldn't cosign on.
02-08-2012, 09:48 AM | #20 |
While I dont agree with you concerning the relative beauty of the 46-47 models, I do agree about wishing I had back all the cars I ever owned. That feeling must be pretty common among car guys.
02-08-2012, 03:46 PM | #21 |
I didn't say I thought they were ugly, I bought it. There is one running around town that is slammed and looks great. Part of the appeal is the rarity.
