Old 02-06-2012, 03:04 PM   #1
vegas80step
vegas80step's Avatar
where should I start looking.. (hard to start)
Hey guys, I think my ignition switch is going.. but thought I'd run it by you guys and see if there is other areas I should look into..
When I turn my key all the way it wont start, sound and feels like my battery is dead. (no crank) If I let off the key a bit it fires right up.
I didn't have this problem when I dropped my truck off for paint (last october)
I'm switching to a push button start next week, I wanted to make sure it was the Ignition before I did. I don't want to have it not work right and not know if it was the new button start or something else..
any ideas?
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 02-06-2012, 03:58 PM   #2
Stepper86
Stepper86's Avatar
Re: where should I start looking.. (hard to start)
Sounds very much like the igniton switch to me, did they take the column apart to paint some covers or somthing while it was at the paint shop?
If they did it might be that something was moved a little when it was put back together. These things wear in over time, and when put back together in a slightly moved position strange things start to happen.
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 02-06-2012, 04:00 PM   #3
beamn7
Sounds like you need to adj the switch itself which is down towards the bottom of the steering column and connected to the lock cylinder with a rod. The switch has elongated holes in order to allow for fine tune / adjustment....
beamn7 is offline   Reply With Quote
Old 02-08-2012, 06:08 PM   #4
vegas80step
thanks for the info. they didn't pull it apart.. but doesn't mean something didn't get out of wack...
cool I'll take a look. thanks
Old 02-08-2012, 09:50 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
check grounds off the batt
may need to scrape off some bits of paint
any chance they lowered/changed the coloum to paint the dash,might moved the switch outa bit
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-19-2012, 02:18 PM   #6
vegas80step
ding, ding, ding... we have a winner.. the rod did need adjusting...
thank for the help guys...
